05-07-2011, 05:20 PM | #1 |
Rear Drop question
i got 4.5 drop on front and 5 drop coils on back. It has too much of a rake, even with my bed on and tailgate (no wood in yet) and it still sits way to high in rear (with 5 inch drop coils). What else can i do on back to bring it down some more?
05-07-2011, 05:48 PM | #2 |
Re: Rear Drop question
Blocks and new Ubolts. 1.5 or 2" should be fine.
Tim Road Hounds |
05-07-2011, 05:54 PM | #3 |
You would figure a 5 inch drop on back would be pretty significant, guess on these older trucks it isn't so as much when i did my 96 truck. thx grumpy
05-08-2011, 10:31 AM | #4 |
Short of building my own , who has the cheapest price on a set of blocks with springs?
Posted via Mobile Device |
05-08-2011, 03:11 PM | #5 |
Check the vendors market place. way2low had a great price on lower blocks.
05-08-2011, 09:50 PM | #6 |
Tot Roddin'
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-08-2011, 11:10 PM | #7 |
Happy to be here
What size wheel do you plan to run? If you are sticking with 15's be aware that you don't want a 2" block. Anything more than a 1.5" will create scrubline concerns.
05-09-2011, 12:04 AM | #8 |
Here is how the rear sits now. It has 5 inch coils on back but still too high from rear, almost looks stock from rear since front is so low. I have a c-notch on back and there is 7 inch between notch and axle. So with 2 inch blocks i would still have almost 5 inch between axles and bump stops.
05-09-2011, 12:07 AM | #9 |
A guy with a truck
Early Classic Enterprise has a 6" drop coil. Pair this with 1.5" blocks (2" with bigger wheels) and you should be sitting just right...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-09-2011, 07:54 PM | #10 |
i don't think you got 5in drop springs on the back! i got 3in drop springs and 2in. drop blocks and a c-notch on mine and the bottom lip of the bed is 12in off the ground! i think i have about 4-5in. between the rearend and the frame! i also have 17's on my truck
