Old 05-07-2011, 07:03 PM   #1
85burb
85burb's Avatar
suburban door striker
I was wondering if you can swap the rear door striker post thing for the front one. My front ones are wore out and passenger side door is hard to shut. I was wondering if i took one off the rear and put it on the front if that would be ok. Also what happens if you unscrew it all the way. They move around and i was wondering if the thing they screw into will fall down or what.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-07-2011, 07:57 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: suburban door striker
All the strikers for the side doors are the same. They screw in to a plate that is loosely held in place, but it should not fall. The plate has to have play for adjustment of the striker.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-07-2011, 10:07 PM   #3
85burb
85burb's Avatar
I figured that thanks. I only open rear doors a few times a month so i will swap them out.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-08-2011, 12:34 AM   #4
ak_nut
you can take and wrap a little electrical tape around the striker to tightin it up
ak_nut is offline   Reply With Quote
Old 05-08-2011, 12:51 AM   #5
85burb
85burb's Avatar
Mine are wore out at the end like someone took a file to them. Where the tip is is all flat.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-08-2011, 03:48 PM   #6
SBTork
Garage wrench
SBTork's Avatar
my local NAPA stocks them for less than $10 each. Well worth the money. When I did my fronts the adjustment plate behind them fell and I had to remove the interior B pillar trim to retrive them, not a big deal, just more time consuming. The rears stayed in place.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 05-08-2011, 04:54 PM   #7
85burb
85burb's Avatar
Hey thanks for the info i will check my local store and see if they have them. I am thinking i need hindges too. Know any where to get them?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-08-2011, 08:43 PM   #8
Edahall
Instead of replacing the whole hinges, replace the pins and bushings.
Edahall is offline   Reply With Quote
Old 05-08-2011, 10:13 PM   #9
85burb
85burb's Avatar
I did that when i worked at chevy and it would seem easyer to just bolt on the hole new thing on my truck. The hindge is 20 bucks and the pins are 10. Have no decided yet due to no money. Thanks for the info.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
