Old 05-08-2011, 12:25 AM   #1
overtimeracing
overtimeracing's Avatar
Proportioning valve
Does anybody have an idea as to where each brake line goes on the proportionoing valve? I'm not sure I got it right. Thx for the help... Kevin
overtimeracing is offline   Reply With Quote
Old 05-08-2011, 01:38 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Proportioning valve
Are the lines not pre-bent for the unit? I know there are two or three 1/8" lines and two or three 3/8" lines right?
Old 05-08-2011, 01:51 AM   #3
SCOTI
SCOTI's Avatar
The prop valves on 73-87's attach on the splash apron in front of the motor. Looking @ the motor....
The outlet on the side facing the driver frame rail is the front driver supply.
The outlet on the bottom of the p-valve is the pass front supply.
The outlet facing the pass side frame rail is the rear line supply (one common line that splits @ the rear axle).
The inlets from the master cyl are the 2 ports at/near the top of the p-valve.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-08-2011, 12:10 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Anyone have a clear pic that we could add the this info? It would make a great 73-87 FAQ.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-08-2011, 12:35 PM   #5
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
This is a quick pic , I really think a trip to the salvage yard would be better .
1984 C30
Name:  prop valve.jpg
1984 K20
Name:  prop valve 2.jpg
1974 K10
powerdriver 1958 is offline   Reply With Quote
Old 05-08-2011, 04:45 PM   #6
SCOTI
SCOTI's Avatar
Working on it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-08-2011, 06:49 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks....
Articles-
"Refining Sierra"
Old 05-08-2011, 08:12 PM   #8
overtimeracing
Those are excellent pictures guys. thanks alot... Kevin
Old 05-09-2011, 10:03 AM   #9
SCOTI
SCOTI's Avatar
1) Front pass side
2) Front driver side
3) Supply from master cyl to fronts
4) Supply from master cyl to rear
5) Rear common
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-09-2011, 11:38 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks to Scot, Dave and all involved. This will soon be in the FAQ forum.
Articles-
"Refining Sierra"
Old 05-09-2011, 12:54 PM   #11
JNJchev77
Registered Cruiser
JNJchev77's Avatar
1) Front pass side
5) Rear common
Scoti, do you know the typical size fitting for #5? I am running all new lines, front is done, and I have the rear set up but my 3/8 fitting does not seem to want to screw into the #5 port? Threads look fine on the Prop valve. I did pick it up from a yard, and the external fitting is brand new. Also, rear line is 1/4 inch, stepped down form the 3/8 fitting... Sorry to steal the thread, but could be helpful here too I guess...
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 05-09-2011, 01:01 PM   #12
SCOTI
SCOTI's Avatar
It is an 'odd' fitting. I do have the exact size but don't have the info in front of me. I'll get it for you & post it up once I have my 'notes' in front of me tonight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-09-2011, 01:19 PM   #13
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Thanks Scoti, I appreciate the help!!
77' Chevy SB
5.3/4l60e combo
Old 05-09-2011, 11:31 PM   #14
SCOTI
SCOTI's Avatar
That rear fitting is a 9/16-18 port to a standard 1/4" Domestic brake line.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-10-2011, 11:38 AM   #15
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Thanks Scoti, now the search for the fitting!
77' Chevy SB
5.3/4l60e combo
Old 05-10-2011, 11:48 AM   #16
SCOTI
SCOTI's Avatar
I've found short pieces of line w/it attached @ Oreilly Auto Parts (<$5) or in a 10 count pack @ Advanced Autp Parts; zilch elsewhere. I had my fitting re-plated to match the remaining fittings.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-10-2011, 11:50 AM   #17
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Ya, looks like a very odd fitting. Thanks for the tips!
77' Chevy SB
5.3/4l60e combo
Old 05-10-2011, 07:24 PM   #18
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Something like this?? Amazon.com: IMPERIAL 90171 CYLINDER BRAKE FITTING... Amazon.com: IMPERIAL 90171 CYLINDER BRAKE FITTING...
well so much for that working...
77' Chevy SB
5.3/4l60e combo
Old 01-21-2012, 11:11 PM   #19
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
This Pic helped me:
66 C20 Service Truck:
Old 01-21-2012, 11:58 PM   #20
LostMy65
LostMy65's Avatar
Just found this at another forum:
Old 01-22-2012, 12:01 AM   #21
LostMy65
LostMy65's Avatar
pasted:
The front port on the m/c connects to the front top port on the combination valve. It's a 1/4" line, and has a 1/2-20 oversize nut on the m/c and on the valve.
The rear port on the m/c connects to the rear top port on the valve. On the m/c there is a 9/16-18 oversize nut, 1/4" line, and a 7/16-20 nut on the valve (standard fitting for a 1/4" line).
The port on the angled surface at the front of the valve, and the port on the bottom front of the valve are 3/8-24, standard for 3/16" line. These 2 ports are for the front brakes.
So - 1/4" line and appropriate nuts from m/c to valve. 3/16" line and standard nuts for the front brakes. 1/4" line and a standard nut for the rear brake line.
Old 01-24-2012, 10:05 PM   #22
LostMy65
LostMy65's Avatar
Here's the fitting needed to connect the 79 chevy truck's rear port of the combination (proportioning) valve to the 60-66 brake lines:
Old 01-25-2012, 02:51 AM   #23
83GMCK2500
This weekend I swapped backing plates from 11" to 13" on my 9.5" 14 bolt, do I need to swap proportioning valves?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 01-25-2012, 11:53 AM   #24
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Just an fyi for some who are looking for this fitting.... I found it at autozone. I looked all over on-line, napa, etc. Check autozone or orielly's if your having trouble.
77' Chevy SB
5.3/4l60e combo
Old 01-25-2012, 11:54 AM   #25
SCOTI
SCOTI's Avatar
You might need to verify you have the correct wheel cylinder for the brakes. They use different wheel cylinders for the C10's standard 2"w vs the HD 2.75" w drum brakes so it might be worth verifying.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
