Old 05-08-2011, 03:39 PM   #1
ATrain707
need help 88 chevy 1500
hey guys i was helping my friend change the tranny oil and filter on his 88 with 350/350, when we finish he took it out for a test drive and he say at about 50 he loses power it wont go anywhere. do you guys have any ideas? this started happening after we did the oil and filter change in the tranny
ATrain707 is offline   Reply With Quote
Old 05-08-2011, 07:42 PM   #2
scotts62
One day...
scotts62's Avatar
Re: need help 88 chevy 1500
Sounds like not enough fluid. Did you make sure to get the O-ring gasket off the old filter before you installed the new one? I have seen the fluid push by it when you double gasket it kinda like when an oil filter install goes bad.
Scott
93 crew cab build
Project 62
Old 05-08-2011, 11:20 PM   #3
ATrain707
no im not sure, ill have to drain and check.
Old 05-09-2011, 09:47 AM   #4
benoit454
Chris
benoit454's Avatar
what type of fluid did you use in it? It has a 350 in it? My 88 had a 700r4 that I swapped out for a th350.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 05-09-2011, 03:32 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I was just going to say it should have a 700r4. I am wandering about there being 2 o ring gaskets on there. I would check the fluid as well first see if its low.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-14-2011, 04:53 PM   #6
ATrain707
well i found out the whole story, my friend hit something and put a hole in the tans pan to the tranny is toast, so we are installing another one, and what Torque Converter should he get i know theres diff stalls, his motor is stock and the trans is a th400? i think
