05-08-2011, 05:43 PM | #1 |
Help Which A/C sys.Vintage Air or Old Air Products
I am to the point of my Frame off resto mod and wonder what the best A/C system to buy. I have always heard of vintage air but recently found out about Old Air Products and they looked pretty good too. There 2 electric fan set up looks fantastic. Any pros or cons from you guys that are running either system would be great
Thanks Tim |
05-08-2011, 06:27 PM | #2 | |
Re: Help Which A/C sys.Vintage Air or Old Air Products
Although in my research I discovered that I'd have to use a different compressor than what Vintage Air offers because I'm running a March serpentine belt system on the 1971...so I wouldn't buy the complete kit from Vintage Air which would include their A/C compressor and brackets. But that's ok because you can just buy what you need from Vintage Air. Bottom line is that I had a good experience with Vintage Air and I'd buy from them again. |
05-08-2011, 06:34 PM | #3 |
Moderator
i have heard nothing but good things about either one...but my personal experience with old air products is excellent.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-08-2011, 06:37 PM | #4 |
I just installed old air system this weekend. It was very simple. Everything worked fine. I could of used more pictures, though. I have non-air cab. Probably spent 8 or 9 hours total on it.
05-08-2011, 07:45 PM | #5 |
Old air instructions SUCK. system works good though.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
05-08-2011, 10:32 PM | #6 |
I went with an Old Air system because the firewall plate is steel and flat and the system allows modification of factory A/C controller. Very happy with it's performance too. Purchased mine through GMC Pauls for a good price as well.
71 Cheyenne SWB Last edited by xmitsu10; 05-08-2011 at 10:33 PM. |
05-09-2011, 01:34 AM | #7 |
Interesting thread...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-09-2011, 11:10 PM | #8 |
Thanks for the inputs I am still on the fence I was going to use Vintage air but I have been reading some good things about Old Air Products . In fact I ordered there dual fan set up today. That set up is hard to beat . Bolts in the factory location and it already is wired with all the relays, fuses and even has a adjustable fan thermostat, the shroud even has flaps in it to let more air flow through the radiator when you are driving at highway speeds.
05-10-2011, 12:25 PM | #9 |
1965 Chevy C10, 2005 4.8L/4l60
Myself and my dad has OAP a/c in our trucks, never have had any issues. I have had mine over 5 years.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-10-2011, 04:31 PM | #10 |
Which ever one you get mount an electric fan on the condenser and it will make a night and day difference on how cold it is.
1970 GMC truck 1988 Harley 1200 Sportster |
05-10-2011, 05:27 PM | #11 |
I ordered the old air dual fan setup that bolts in the place of the fan shroud do you think it still needs fans in front of the condenser ?
05-10-2011, 05:44 PM | #12 |
Spanked once
No way , I have that fan set up on my 71 and it is a nice piece ,use a trianary switch on the ac line to turn on the second fan for the ac. I run mine off a engine heat sensor.
The ole 350 budget build. |
05-10-2011, 07:39 PM | #13 |
Yeah with the dual fan setup you will be just fine. I had the mechanical fan on mine and it didnt pull enough air for the condesor. I have the jeep fan conversion on mine now.
05-10-2011, 08:37 PM | #14 |
Ok Cool thanks Gotta make sure that this thing cools good because it was my grandfathers truck he bought it 70 new. got in a head on collision about 15 years ago just about done with it finally going to give back to my 81 year old father and want to make sure he doesnt get hot driving in it . ( Really going to be me driving him around lol )
05-11-2011, 12:37 PM | #15 |
that is so commendable, it will make him feel so good! I admire your intentions.
05-11-2011, 10:53 PM | #16 |
Thanks I went a lil to far with this one 5 7 drop on 20 inch coys lol but he seems to like it.
Tim |
05-11-2011, 11:14 PM | #17 |
Moderator
Too far? Sounds absolutely perfect to me
05-12-2011, 01:01 AM | #18 |
Somebody tell me how to ad some pictures I would like to see what you guys think of my build
Thanks Tim |
05-12-2011, 02:51 AM | #19 |
Laid Back
Vintage in my experiences is a much better product but my uncle is also a dealer so alot cheaper for me but thats just my two 2 cents I have it in my camaro and truck and soon to be blazer
Posted via Mobile Device |
05-12-2011, 10:31 AM | #20 | |
Has more rust than truck...
Upper right side, click upload photos, then up load them and click on the picture in your gasllery copy the link below the pic and paste it into your reply. Hope this helps. |
05-12-2011, 12:46 PM | #21 |
I used Old Air. I have a smoothed firewall, so I had to build a bracket thing for the interior unit to mount too. Luckily I did all of this before I had the truck painted since I had to weld to the firewall. I don't know how vintage air mounts, and I don't know if you have a smoothed firewall, but its something to keep in mind.
