03-27-2003, 07:52 PM | #1 |
Seņor Member
Size of poly Blazer tank fitting anyone?
For those of you with the poly Blazer gas tank, yours probably came with several smaller plastic fittings-- two on the filler neck side and one on the other. Well, I can't find the two I never used... and I need to pick up one so I can install some kind of charcoal canister. Has anyone got a spare one of these fittings laying around? Can you measure it so I can go a-lookin' for one locally?
Thanks in advance, Kenneth
03-27-2003, 10:08 PM | #2 |
XXL,
I just got a poly tank in from GMCPaul today. The male fittings are bronze. Are these the ones to which you refer? Tell me exactly what you're looking for and I'll try to get a measurement. Brian |
03-28-2003, 01:12 PM | #3 | |
Seņor Member
Thanks, Kenneth
03-28-2003, 01:21 PM | #4 |
Are you looking for the diameter of the hole? The length of the fitting? The diameter of the fitting?
Let me know and I'll measure it when I get home tonight. |
03-28-2003, 01:21 PM | #5 |
03-28-2003, 01:25 PM | #6 | |
Seņor Member
Thanks, Kenneth
04-10-2003, 07:06 PM | #7 |
Seņor Member
Anyone?
04-10-2003, 07:24 PM | #8 | |
Hope that helps. Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
