05-08-2011, 08:29 PM | #1 |
New Member - First Post & Question
Hello, All! New to the board and first time poster...
Own a 72 Cheyenne C10 LWB. Doing a frame off stock restoration. Just rebuilt the entire chassis/suspension. Now that it is just a rolling chassis, the tail end of the right frame rail is 1/2" higher than the left side. I installed new Moog coil springs, but used the stock track bar with new bushings. Any suggestions on why the right side is sitting higher? Or is this normal without any weight on it? Thanks in advance for comments! Last edited by Econman; 05-08-2011 at 08:33 PM. |
05-08-2011, 09:33 PM | #2 |
Man of Mini-Talents
Re: New Member - First Post & Question
I'd say it's normal until you get some weight put on it.
Welcome to the board, and just so you know...
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro Last edited by Zoomin; 05-08-2011 at 09:34 PM. |
05-08-2011, 11:32 PM | #3 |
Welcome! Just go ahead and make this site one of your "favorites" now.
I'd wait as well, until you get some weight and let the spring settle a bit. |
05-08-2011, 11:40 PM | #4 |
VA72C10
the frames are easy to tweak w/out weight and springs can take a bit to settle.
Looking for a 67-72 swb or blazer project in or around VA. |
