Need some help ID'ing a GMC
I recently inherited a 1968 GMC truck: VIN is CE20DZB21303. A quick GOOGLE search came up with nothing, can you guys help?
hope this helps you out, the GMC is different than Chevrolet, look at LMCtrucks.com for more assitance:
CE20DZB21303 C= 2WD E= V8 engine 2= 3/4 ton model OD= 67-69 fleet side bed Z= maryland state specific B= 1968 year model 21303= sequence number built in 1968, in this example #21303 built that year Post some pics of the Glove box SPID sheet, I'l try and help more AC Still in Afghanistan
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 |
Re: Need some help ID'ing a GMC
What's the SPID sheet?
Vintage 4x4s
Looks different than a 67 GMC vin. I think the Z is for Fremont, CA assembly line. the spid is the service parts ID sheet inside glovebox.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Man of Mini-Talents
Service Parts Identification. I will be glued to the inside of the glove box door.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
yeh go on LMC truck Like AC says put in your make and model view full catalog and the VIN coding will be within the first 20 pages
on page 10 of the 2010 LMC truck catalog, the GMC vin is different than a Chevy. I missed a part of the VIN, so here is the correction for the GMC
C=2WD E= V8 2= 3/4 ton OD= 67-69 fleet Z= Maryland state specific B= Baltimore assembly line 2= 1968 model 1303= sequence number built hope it helps. Check out lmctrucks.com for the catalog. AC Still in Afghanistan
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 Last edited by a.c.ward; 05-08-2011 at 10:14 PM. |
