got the tank in today,didnt figure it take that long the bots supplied in the kit were kinda strande so i just cut up some threaded rod and wiled nits to the end. then i drilled hole and tacked the rod and nut to the frame. tighted everything up and done. i just can remember home much u need to cut off the cross sil in the bed does anyboy know 1 3/4 ? something like that also get the frame alsost done. the red is eching primer btw. -kyle
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
ngcfj
blurry
nobody knows how much i need to cut from the cross sill?
ttt
Sorry, don't know.....but your project is looking good.
I did that about a year ago. I think you need to cut maybe 1.5 - 2 inch out of the still. I remeber there wasn't much left of it when I got done. You did yours the easy way. the bed was on my truck when I put the tank in.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
