can a gear box be rebuilt?
just wondering if a gearbox can be rebuilt....starting to get some play
One day...
![]() Join Date: Apr 2008
Re: can a gear box be rebuilt?
Way easier to just buy a new one. Not sure if they can or not but i have heard some bad stories of a rebuild gone wrong.
Redefining LowBudget
rebuild?? I know there is some adjustment in them BUT if its worn only centered then the worm gear is worn and if you adjust it then it wil be TO TIGHT at the rest of the turning swing... try turning your wheel to one side and see if you have play there..if you do you can loosen the 9/16" might be 1/2" jam nut then turn the center bolt ( might be a screw driver,small bolt or allen wrench I can remember) 1/2 turn in and try it again...be gentel with adjustments.....this should get the play out....
Be careful not to over adjust it...obviuosly the center wears out first since the wheels are there most, so make your adjustments with the wheels turned off center.. AND CHECK THE REST OF YOUR STEERING PARTS FIRST including the rag joint good luck and let us know if it works
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
here, just not logged in
^^^^ Should this be done with the truck running, since its power steering or does it matter? Also should the truck be jacked up or on the ground?
Iluvmy72, you have any luck trying this? |
Chris
gear boxes can be rebuilt they showed it on muscle car awhile back.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
Newbee
If you rebuild it, the balls inside it are two different sizes. If they are not staggered perfectly, it will not turn. Get a good book, and dont attack it blind like I did. I still have that box, and someday I will tear into it again.
If you have play in the wheel, it's more likely not the gearbox, but rather other worn suspension parts; pitman arm, idler arm, rag joint, tie rods.
| Bookmarks |
