Parting 70 C-10 Long Bed 2WD
EDIT: This truck is long gone, but I have a gang of parts! I will be parting this truck this week and making a trailer out of the back end.
Please respond in thread to avoid confusion. Thanks, Ray tired 350 engine- #150 local SOLD sm465- $100 local grille with trauma on right side- $100 local SOLD power steering box- $62 shipped alternator brackets- $40 shipped crank and w.p. pulleys- $27 shipped clutch engine pivot bracket- $20 shipped ram horns- $50 pair plus shipping SOLD door panels- $30 pair plus shipping SOLD clutch/brake pedal assembly- $25 plus shipping visors- $25 pair plus shipping radio patch- $25 plus shipping C-10 fender emblems- $22 pair shipped 2 barrel carb- $35 shipped fan- $20 plus shipping point distributor- $25 shipped heater box (engine bay side)- $40 plus shipping SOLD small block engine stands- $20 shipped Last edited by KrazyRay; 08-01-2011 at 05:02 PM. |
Re: Parting 70 C-10 Long Bed 2WD
pics
more
![]() Join Date: Nov 2010
Ok how much to ship power brakes to 38237? Booster, master and valve?
Jerry Galey ![]() |
#5 | |
Thanks, Ray |
Ray,
How much for the Alt brackets, all crank and wp pulleys, and the ps pump and brackets, shipped to 32803, business address? Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
How much for the hub caps?
Posted via Mobile Device |
![]() Join Date: Apr 2007
Hi Ray, how much for the steering wheel. Thanks, Sharpie
FL71C10- $95 shipped for everything...I have a ps pump and brackets from another truck as this truck had a non factory setup on the ps.
tampz- $50 shipped on the hub caps sharpie- $20 shipped...its not a good wheel imo. Thanks, Ray |
Ray,
Is that the one I told you about from Davis. I hope it is, that work be cool. Brian |
Brian, That's the one...I was third in line and the other two flaked.
nice, I'm glad you got. I might have another one for you. I'll PM you later.
#13 |
Hi Ray,
How much for both door mirrors and both wiper arms w/ blades shipped to 24078? Thanks
![]() ![]() ![]() 1970 Chevy C10 LWB 307 3OTT 3.73 gear |
#14 |
Grandpa in the rustmobile...
Does it have a good antenna?
I need the longest heater cable also, (if not kinked or bent, alreayd have one of those).
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#15 |
Brian- Thanks! A truck a week is all I ask.
ChevyLvr4Life- $55 shipped for the painted mirrors and trico wiper arms and blades. oldblue- The antenna is junk and the cables were modified for the aftermarket air. Thanks, Ray |
#16 |
Hi Ray, $20 sounds good. I have a buddy that wants one for a rat project. PM payment details. Thanks, Sharpie
#17 |
pm sent
#18 |
VA72C10
![]() Join Date: Mar 2008
are the brackets by wild chance correct for our trucks? If so, I'd take them
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#19 |
#20 | |
VA72C10
![]() I saw a recent fs post where there were aftermarket buckets but factory bucket seat mounts....
#21 |
How does the Engine wire harness look?
#22 |
how is the shape of the hvac unit under the dash and hoses and how much shipped to
60435 |
#23 |
QUOTE=KrazyRay;4670895]FL71C10- $95 shipped for everything...I have a ps pump and brackets from another truck as this truck had a non factory setup on the ps.
Ray, Will I be able to use this to convert my truck over to a short water pump pulley set up without having problems. Could you bolt the ps pump on and make sure the pulleys line up? Thanks!
#24 |
any tail gate trim?
#25 |
PM sent
