Cadillac 500 1979 chevy K30 1 ton 4WD
And I have some questions. I was given a 500 from a 1973 Eldorado FWD and have a couple points I wanna hit. The truck is a 1979 chevy K30 1 ton dually
with a turbo 400, np205 and a GM10.5 14 bolt 4.56? - Motor mounts make my own or get the frame mount and pad from a 1977-79 deville? - BOP with the trans fit on the back of the motor being cadillac used a turbo 400 too? - oil pan can i use the existing oil pan on the eldorado rear sump? - torque converter use the existing flywheel on the 500 and get a converter for a eldorado? thanks! Last edited by sameoldthang; 05-09-2011 at 08:02 AM. |
#2 | |
Redefining LowBudget
Re: Cadillac 500 1979 chevy K30 1 ton 4WD
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Here is a buildup of K5 with the same engine and trans. http://4x4mecca.com/forum/truck-gall...ct-torque.html Maybe there is some things you can use for yours.
Bruce 73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD http://i56.photobucket.com/albums/g1...Rusti192-1.jpg |
I would use one of these. In this case I think it would save a lot of time.
http://www.jegs.com/p/JEGS/JEGS-Engi...51074/10002/-1
1977 GMC Sierra Grande |
yea but if he owns a BOP trans why not use it?? that might comeinto play someday but I would keep the $50 in my pocket
#6 | |
Moderator
![]() Join Date: Oct 2008
BAD BOW-Silverado XST
You can find parts and adaptors at http://www.cad500parts.com/
Welcome to the site. The 500 is lighter than a 454! It makes gobs of torque!! You'll really like it. |
