Old 05-09-2011, 11:59 AM   #1
smarthead
87 1ton 2wd- Front end work
Hi Guys ,
I have been reading over the form for a while and thought well i am going to write something up !
I am stuck right now with a job were are doing in the shop,
We have a 1 ton 2wd, we put all NEW control arm (uppers and lowers) plus we are putting new coil springs in to, so here is the issue we put all this new stuff in and well what is the best way to get the control arm tubes up to the sub frame to put the u-bolts on with out the spring jumping out and killing someone ?
Just with the 1 ton hd springs it's not very fun to work with !! LOL
Any help would be Great !!!
Thanks again for your help
-Nick
smarthead is offline   Reply With Quote
Old 05-09-2011, 09:00 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 87 1ton 2wd- Front end work
ive always on these trucks and all gm products have iinstalled springs with the LCA attached and used the weight of the truck to allow the springs to seat.. you may have to compress them slightly with a spring compressor
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-09-2011, 09:19 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You need to install all the A-arms first. Then use a floor jack on the lower a-arm to compress the coil. When the coil is in place and before compressing, use a strap or chain to hold it in place. Leave the strap on until the spidal is tightened down.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-09-2011, 09:21 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Another option is to use a transmission jack if the truck is on a lift. First install the upper arm to the crossmember, hang the spindle, and attach the lower arm to the spindle too. Set the spring in the pocket, and swing the lower arm in place. Use the tranny jack to compress the lower arm and spring until you can attach the u-bolts.
I have never done it on a 1 ton, but it will work on a 1/2 ton.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
