05-09-2011, 05:20 PM | #1 |
pull a part find
I got a Hurst floor shifter for the 3 speed out of a '70 c-10 Saturday for just under $17. Someone had already pulled the trans out and driveshaft. My brother got the driveshaft for his '65 and the trans for a racing buddy. It has the wider rear end, but I could not get the bolts to break loose. We sprayed it with PB Blaster, then sprayed it again, pulled on it and nothing. Got tired of it and just left it.
05-09-2011, 06:09 PM | #2 |
Re: pull a part find
Cheater pipe.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
05-09-2011, 06:53 PM | #3 |
lots of times i find it helps to have a hacksaw at pull a part places
05-09-2011, 07:57 PM | #4 |
Grandpa in the rustmobile...
Lots of Pb and a big breaker bar a a cheater pipe a foot taller than you lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-09-2011, 08:17 PM | #5 |
VA72C10
agree...pb blaster and a cheater pipe...then if not, a battery powered sawzall...
Looking for a 67-72 swb or blazer project in or around VA. |
05-09-2011, 08:19 PM | #6 |
Could you heat it with a torch? Or could you cut the bolt off with the torch? (BAD way to do things)
05-09-2011, 09:11 PM | #7 |
I had the cheater to fit over a rachet, but it would not fit the wrench. The nut is 1-1/8" and I didn't have a deep well socket for it. Probably a good thing though because the guy that drilled my brother's axles just sold his machine shop and accepted the call as a full time pastor for a church. He had been their interim, but they called him last week. He always did work for CHEAP for me and my brother. Now I will come out the same just buying a '71 or '72 to get the 5 lug.
