05-09-2011, 10:05 PM | #1 |
Power Drum Brakes On A 64 Short Fleet
Im considering taking a 64 short fleetside truck in partial trade for my 55 Bel Air .The truck has manual drum brakes all around ,how would I convert it to power drum brakes .If I get this truck I plan to drive it a while to see if its a keeper or sell it after my 72 short fleet is out of restoration but would like to be able to stop it better.
05-10-2011, 12:59 AM | #2 | |
60-66 Nut
Re: Power Drum Brakes On A 64 Short Fleet
There are a few ways. 1) you can go with an original style booster, but I think the 'wedge' is a little hard to find. 2)You can go with aftermarket booster from suppliers such as CPP, ECE, etc. 3) you can buy the booster bracket that I sell and use either a wrecking yard booster, or a new/rebuilt unit from your local auto parts supplier.
Are you wanting to convert to a dual reservior master at the same time? It really is pretty easy and inexpensive to convert to front disc brakes using OEM parts, and well worth the effort and $$. Quote:
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-10-2011 at 01:00 AM. |
05-10-2011, 07:33 AM | #3 |
If I get this truck all I plan on to start is the booster and master cylinder swap if that will work but what would it cost to put power disc on it as well ? Not sure if this truck will be a keeper or not but power disc might be a good selling option later down the road.
05-10-2011, 09:53 AM | #4 |
very popular mod - bunch of threads around here - start in the FAQ sticky at the top of our board. a 73-87 swap is popular but theres also a bunch of aftermarket options too
05-11-2011, 12:44 AM | #5 | |
60-66 Nut
Cost would depend on what you can get a '73-'87 C10 front suspension for. Or at least the spindles and everything attacked to it, as well as the steering linkage, power steering box, master cylinder and prop valve.
