Old 05-09-2011, 11:58 PM   #1
matthew.doan
do you have cab mounts for s-10 frame f/s?
does anyone on here build and sell the mounts for a s10 swap?
If so do you have a good price?
Im not very good at building them
thanks matt
matthew.doan is offline   Reply With Quote
Old 05-12-2011, 01:19 PM   #2
rollinrooster
rollinrooster's Avatar
Re: do you have cab mounts for s-10 frame f/s?
thanks matt
From what ive seen most of the mounts are different depending on how low/high you want the cab. I made mine and mounted my cab about 3.5 inches off the frame. This way i dont have to make a tunnel for the driveshaft. The cab mounts are probably one of the easier parts of the swap. Once you get the cab mounted all the other fabrication has to take place. Im not trying to steer you away from doing this just want to give you a heads up that there is alot of fab. work involved in a s-10 frame swap.
rollinrooster is offline   Reply With Quote
Old 05-12-2011, 03:08 PM   #3
jimig1
jimig1's Avatar
this is one place that makes a kit http://www.e-zchassisswaps.com/1947.htm I know some one here is using them to do the f/s
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
