Old 05-10-2011, 12:51 AM   #1
55dude
55dude's Avatar
75' c10 rear into 69' c20 truck
guys, other than the mounts being different are the newer rears wider and if so how much? thanks.
55dude is offline   Reply With Quote
Old 05-11-2011, 12:14 AM   #2
sduckworth13
sduckworth13's Avatar
Re: 75' c10 rear into 69' c20 truck
I am doing a swap on my 1967 GMC 3/4 ton with leafs only ( no coils ). The previous owner had installed a 14 bolt GM Corporate, I'm doing a disc/drum 5 lug conversion and full suspension swap using a 1974 chevy 1/2 ton as my donor vehicle. The only thing I had to move on the rearend was my shock mounts, I am doing a 4/6 drop. Waiting to install my shock mounts after I install the flip kit on the 1974 Chevy 1/2 ton truck 12 bolt, but the leaf springs lined right up without any issues.
sduckworth13 is offline   Reply With Quote
Old 05-11-2011, 12:16 AM   #3
sduckworth13
I believe its 1 1/2 inches wider
Old 05-11-2011, 12:26 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Yep, 3/4" per side, assuming they're both 12 bolts...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
