Old 05-10-2011, 12:52 PM   #1
csb#356
Loose mirrors
If I take my truck onto the highway within about a minute the mirrors are blown up against the window. It is not very helpful to be able to see myself in my passenger mirror so is there anyway to tighten these up or do you just replace them. If replacing is the only option how do take them off. I didn't see anything holding them on from the inside of the door. Oh my truck is a 1977 by the way.
csb#356 is offline   Reply With Quote
Old 05-10-2011, 01:26 PM   #2
Rons86
Rons86's Avatar
Re: Loose mirrors
If your mirrors are the "dumbo" type you can take the cover off by removing a screw at the bottom and tighten them up.
Rons86 is offline   Reply With Quote
Old 05-10-2011, 10:30 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Loose mirrors
its tricky to wiggle the outside chrome up
but keep the posts' rubber seal in place (on cover)it's hard to work back in if it's brittle
and you will see the bolt
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
