Old 05-10-2011, 07:10 PM   #1
TexasSixtyFourSW
TexasSixtyFourSW's Avatar
Need help identifying year of my suspension
Hi Everyone,
I have been lurking for quite a while trying to get my project off the ground. Long story short--I first bought a 64 BBW Short Fleet that is a huge project and decided to find something running and driving. I found a 63 BBW Short Fleet and I am going to use all my parts on the 63. The 64 I bought has been converted to 5 lug and I would like to use that suspension on the 63. I don't plan on doing the suspension swap for a while and would like to lower the 63 as much as I can ( Six Lug right now) using coils. I realize the spindles are not intrchangeable between the stock 63 and newer suspension but if I buy coils to drop the 63 can I use the same coils on the new suspension? I will buy dropped spindles for the 5 lug suspension after the swap more than likely. If anyone wants to share their ideas or thoughts it would be greatly appreciated. I also wonder if anyone can tell by the pics what year my suspension parts on the 64 are?
TexasSixtyFourSW is offline   Reply With Quote
Old 05-10-2011, 07:29 PM   #2
slepysal
slepysal's Avatar
Re: Need help identifying year of my suspension
HMMMMMMMM the grill is off of a 62, and if it looks like you have no coil springs do you have torssion bars?. If that is the case it is a 62 not a 63. You can always swap the whole cross member ftom the 64
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-10-2011, 09:31 PM   #3
awbrown
Welcome to the forum, I know what it is like to have one truck as a long term project and wanting one as a driver .. I have a 63 in process and am just getting my 63 I bought in Feb. on the road .. What I thought would take a few weeks has taken 3 months and wad of cash .. But I am happy with it ..
The picture of the suspension looks like a typical mid 70s up suspension ...The master cylinder looks like late 80's up .. If I were you I would just get it safe to drive and torch a coil or 2 out of the springs and enjoy it , you dont want it to become long term project # 2...
awbrown is offline   Reply With Quote
Old 05-10-2011, 10:03 PM   #4
chad64chevy
chad64chevy's Avatar
i would have agree with awbrown with the suspension, the master looks like its off a 80's car, i might be wrong about that but it looks like the same as the one thats on my g-mas caprice!!
chad64chevy is offline   Reply With Quote
Old 05-10-2011, 10:39 PM   #5
TexasSixtyFourSW
Thank you for all the greetings and input. The blue truck is definately a 63 as indicated by the vin and has coil spring suspension. The pics of the suspension are from the white truck shown in my avatar. I was really trying to decide if the suspension was from a 70's or 80's era suburban (as informed by po) and if the coils springs were different from those two era trucks? Thanks again for all you input.
Old 05-11-2011, 12:04 AM   #6
SCOTI
SCOTI's Avatar
The suspension in the pics is from a 73 or later truck becaquse of the bushings in the a-arms.
The alum master cyl is from a later year model truck (81 or later). If everything came off the same burb, I would say it was from one built after 81 (or the master was replaced w/a later unit). The coils are not exactly the same but can be interchanged.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-11-2011, 01:26 AM   #7
Captainfab
60-66 Nut
I agree with ScotI
If those aluminum wheels are possibly from the donor vehicle, then it would definitely be an 80's vintage.
Old 05-11-2011, 07:35 AM   #8
TexasSixtyFourSW
I was thinking it was 80's era but needed some confirmation from someone who has been around these trucks longer than me. The way the PO was talking all the suspension came from the same burb.....so that makes sense. Thanks everyone for the help....this forum is great. I hope to start my build thread soon so you all can see what I am up to.
Old 05-11-2011, 09:06 AM   #9
kieth
kieth's Avatar
I used the front end from a 91 burb and have the same wheels on it as yours......the 91 had abs brakes so the master cylinder looks different than yours, Kieth
kieth is offline   Reply With Quote
Old 07-10-2013, 09:00 PM   #10
68chvy
I bought a 68... The ride is pretty rough.. I just wanna change out all bushings.. And I'm not sure what to order.. It is 5lugs up front... Please and thanks for any advice/comments
68chvy is offline   Reply With Quote
Old 07-11-2013, 12:44 AM   #11
Captainfab
60-66 Nut
The steel control arm bushings were used on the C10's from '63-'72. The C20's continued up thru '87. It is difficult to see in that pic but it looks like you may have '73-'87 spindles and such judging by the dust shields.
Old 07-11-2013, 01:26 AM   #12
19666Trucker
19666Trucker's Avatar
Use a cut off wheel to cut springs, there is less heat produced this way. That's if cutting springs
19666Trucker is offline   Reply With Quote
