Roto Reuter thats the name...
![]() Join Date: Feb 2010
Please help me identify this rear end
This rear end is in my '69 C20. I have no idea what it is, or if its the stock rear end. There are no tags on it that I could see. Any help is appreciated.
I would also like to know the ratio. Without opening the pumpkin can I tell by rotating the wheels? With the trans in neutral I turned one of the rear wheels two full times around and the driveshaft turned over four times.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Re: Please help me identify this rear end
I think I have the same rear end so saving
![]() Posted via Mobile Device
1969 Chevy c20(Miss Hackjob) |
Looks like a "corporate" rear if Im not mistaken. My 68 3/4 ton
has the identical pumpkin with rear coils as well. I was told they only came with 4.11 or 4.57 cogs. I cant confirm this. I think eaton made them. Also known as either ho52 or ho72. I think???
1968 C20 Stepside 350 sm465 4.57 - Summer Cruiser/Hauler 1980 El Camino- lil brothers dd. lt1 3.90 1970 Camaro-468 bbc t56 4.11 MONSTER! younger brothers project |
Yeah,HO52 in 20 series and HO72 in 30 series,it's known as the Corporate rear or in GM parts books as "Non-Dana",and HO52s go came in 4.10 and 4.57 ratio. Both the 52 and 72 are the same in single wheel version until you get to the brakes and wheel bearings. The dual rear is just narrower. The differential is made by Eaton. You should be getting a bit past 4 to a bit past 4.5 spins from the driveshaft to one spin of the wheel. Is the truck a 4spd or auto? Chances are,if it's an auto it's a 4.10 and a 4.57 if it came with auto.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 05-11-2011 at 08:05 AM. |
Thats a Eaton with a H072 center section (load bolt on the side of the pinion gives it away) The H052 and the H072 are identical rears except the H072 has a load bolt. Both center sections interchange fine, as I have the H072 carrier in my H052 rear.
To determine the ratio jack one rear wheel up (assuming it dosnt have a locker) and mark the driveshaft and the wheel that is in the air.Truck in neutral and spin the wheel 2 full turns while counting the mark on the drive shaft. If the drive shaft turns a little more than 4 turns, it is the 4.10, 4 and a half turns 4.57's and so on. Now if you jack one wheel up and you cant turn it with out the other one being in the air, i.e. they both go the same way when turned then you have a locker, or boud up spider, etc. Do all I said but only turn the wheel one time to get your ratio |
#6 | |||
So it sounds like normally H052 came in C20's and H072 came in C30's? So did someone swap this rear end?
Also, since I haven't had this truck long I should probably change the rear fluid. What do I need to do, and what gear fluid and gasket do you recommend?
#7 | |||
If it had a locker/spool the spiders are then out of the equation and one turn of the wheel would then turn the ring gear one full turn Quote:
For fluid I use just run of the mill 80w-90, for a gasket I use ultra grey. the bolts that hold the rear cover on are threaded all the way into the housing, so put some sealer on them when you put them back in. If you plan on removing the cover to change the fluid, you can check the ratio then. My "guess" on the entire thing is your truck originally came with 4.57's as most C20's did. Most C30's had 4.10's. Thus the carrier was swapped out some where to take advantage of the 4.10 gears, thats exactly what I did to mine. 4.10's with a 245/60/18 isnt too bad on the road, about 2800-2900 at 60 mph |
#8 | |||||
Nice looking truck for sure. 4.10's would be what you have.
On the gasket scrape everything off and just use a bead of ultra grey, I have never had luck with a rear end cover gasket. I have never seen a 265/60/15, maybe you have 255/60's? Those are a pretty common size. If you did have 255's you would be looking at about 3100 rpms at 60mph. Which isnt great, but isnt the end of the world either |
Sorry, my mistake... 275/60/15's is what I have.
its all about the +6 inches
I've owned 2 3/4 tons with the deflector bolt, and seen planty more. I am believing less and less that the bolt deal is an HO72 only item.
How can I be sure then what rear end have?
#13 |
regardles if the thirdmember, the rearend is a corperate rear with an eaton dropout third member. We know the axle is a 3/4 ton due to the small drums and coils, a C/30 couldn't be had with coils and even the single rear wheel ones had larger drums.
Since you confirmed that the truck is a 4.10 gear, and it has a TH350, I see no reason to think anyone has messed with it. I say HO52 Eaton diff |
#14 |
I just found this Thread and it answered a lot of my questions. I was trying to figure out what I had for a Rear End in my 1971 Chevy Morfidite. This looks just about like what I have - except the truck has leaf springs? Any idea if that is close to stock - leaf springs??????
I believe the body is off a 1/2 T but the frame is all leaf spring and I believe was 3/T. Has a non syncro low first gear and a 205 transfer case. Came with a truck bed and a 400 small block but I put a flat bed on it - and a 350 in it - ![]() Any way thanks for the info this cleared up that it is at least an Eaton with a load bolt, 8 stud wheel's and I'm guessing it's a 4.11 ratio running 32" tires. I didn't realize it was made of pieces when I bought it but it seems to be a pretty good truck. LBM ![]() ![]() |
#15 |
I have one of these in a 67 Forest Service Truck. Ratio is 5.13:1. Not exactly freeway rated. Just want a complete record in case somebody else stumbles on this thread later on.
#16 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
My '72 K20 has an Eaton diff with the load bolt. I'm 99% sure it's original -- the truck was five years old when I bought it, and everything appeared to be original.
#17 | |
![]() Thanks - maybe my truck is more stock then I thought - I think the front is a Dana 44. It has disc brakes on the front - I guess that's stock???? It also has a steering stabilizer that looks stock but everywhere I look there is not a listing for a 71 with a steering stabilizer (Dampener) I can match one that looks like it- double eye - but it's odd there is not one listed. LBM ![]() ![]() |
#18 |
![]() Join Date: Apr 2008
This site might help.
http://coloradok5.com/axleguide.shtml
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#19 | |
Tim |
#20 | |
#21 |
#22 |
My dos centavos.
There should be a code stamped on top of your carrier on the input shaft side. The first two letters will identify what series it's for (10,20 or 30), the ratio, and if it had positraction or not. The codes are listed in the Chevy Truck Parts Catalog. Mine is JU (Series 20, 4.10, no posi). Pic of mine showing code below. The Service Manual for 1969 calls the "load bolt" a "ring gear thrust pad". Fig. 34 on page 4-17 is for both 5200 and 7200 lb. axles and shows the load bolt for both. I'd suggest you get both the Service and Overhaul Manuals for your truck. Also, the Parts Catalog can be very useful. I don't know how I'd manage without the Manuals even with the excellent advice available in this site. If you are considering overhauling your brakes, you might want to look at my project thread, link below. I wrote about my experience with brakes like yours. Nice truck have fun with it !
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 Last edited by bollybib; 05-30-2011 at 12:05 PM. |
#23 | |
Thanks - good info - also good write up on brakes - I'll save this one also.
LBM ![]() ![]() ![]() Quote:
#24 |
I did not mean to hijack this thread but it is exactly what I need, I too have a 69 3/4 ton with the HO 52 my question is , what is the adjustment procedure for the load bolt or adjusting screw for the ring gear thrust pad? Mine had been messed with and there is no procedure in the service manual. I loosened the lock nut and tightened the bolt snug and backed it off one full turn then tighten the lock nut.. I turns freely and makes no noise. If anybody can give me some information I would appreciate it,
steve "The Service Manual for 1969 calls the "load bolt" a "ring gear thrust pad". Fig. 34 on page 4-17 is for both 5200 and 7200 lb. axles and shows the load bolt for both." |
#25 |
Does anyone know where to get parts for the H072/H052 rear ends im needing spider gears and pin for mine!
triple d |
