trailing arm setup
i pulled a trailing arm setup off of a 70 lwb truck, is it the same setup as a swb or did chevrolet manufacture different setups. trying to convert a 72 jimmy to trailing arms
Re: trailing arm setup
they are all the same
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
The 3/4 ton truck arms are like the 1/2 ton arms but have additional plating on the top & bottom for reinforcment.
very true Scoti, i forgot that bit of info. 1/2 ton arms can be made as strong or stronger than 3/4 arms quite easily.
