Old 05-10-2011, 10:25 PM   #1
79gmcclassic
79gmcclassic's Avatar
what to do?
okay, so i was in the process of taking off my wheel arch trim on my truck. this trim hasnt been off since 1979 so its on there good! and i got all screws but one stinking screw! and its really starting to pi** me off! any suggestions on what to do? thanks guys!
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 05-10-2011, 10:37 PM   #2
tucsonjwt
Re: what to do?
PB Blaster or WD40 on the back (threaded) side of the screw and let it soak. Small vice grips on the back side to turn the threads. If too badly rusted in place you will have to snap the head of the screw off and drill out the rest of the screw with a smaller diameter drill bit, but I'll bet some lubrication will get it out. Good luck.
tucsonjwt is offline   Reply With Quote
Old 05-10-2011, 10:40 PM   #3
79gmcclassic
Re: what to do?
i tried WD 40 but i didnt try using vice grips. thanks man!
Old 05-10-2011, 10:43 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: what to do?
if worst comes to worst you can grind off the head of the screw with a dremel
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-10-2011, 10:43 PM   #5
71swb4x4
71swb4x4's Avatar
Re: what to do?
Put the other screws back in.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-10-2011, 10:44 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: what to do?
works for me
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-10-2011, 10:53 PM   #7
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: what to do?
I'd try pb blaster.....I ended up using that when I had a really really tight sealt belt bolt...and it worked...and this bolt was so tight that when I tried to use a breaker bar I hurt my back bracing and the bar started to bent.....
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 05-12-2011, 07:56 AM   #8
79gmcclassic
Re: what to do?
i got it off, but thanks guys!
Old 05-12-2011, 03:29 PM   #9
chrismoore701
chrismoore701's Avatar
Re: what to do?
For all you guys that run into this again. I have a version of this tool
http://www.harborfreight.com/impact-...ase-37530.html
And damn it works great when you need it. You just put it on the screw and crack it with a hammer and bam, it is loose. Just used it this weekend trying to get my mirror and vent window off. Just another good tool.
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is online now   Reply With Quote
Old 05-12-2011, 10:55 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
Re: what to do?
might be overkill for removing trim,but still a good tool
John
