Old 05-11-2011, 04:38 PM   #1
Str8burban
Brakes and lugs
Ok finally have my burb but I still havent gotten my pics up yet, but I will tonight.....here is my problem.
I have drums in the front and drums in the back (69 GMC 1/2 ton) 6 lug pattern.
I am just tring to figure out the cheapest way to get to 5 lugs, and the best way.
really I wouldnt care if they stayed 6 lug, but I dont think I can get any new style wheels on because of the drums, so I figure I need to get the front and rear disc conversions( $$$$$ ouch) and then it would still be 6 lug but then i could get new style wheels on.....correct??
I just dont have all the money right now to do it all, can the factory drums be machined down (the lip) would just love some input on the best way to do this. I havent looked at my drums yet either, that is just what I have been reading on here. basically wanna know how to get new style wheels on my burb, and not spend 2000 dollars on the brakes at this time.????
Str8burban is offline   Reply With Quote
Old 05-12-2011, 09:13 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Brakes and lugs
any chance you can find a parts truck from a 71-87??....you could change out the complete front cross member and wala you got discs
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-12-2011, 09:34 AM   #3
Str8burban
Re: Brakes and lugs
what about the rear end? can you take a springed axle and cut the perchs off and make it set up for a rear coils?
Old 05-12-2011, 09:50 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Brakes and lugs
If I were you, I'd use the rearend out of a 71-72 coil spring truck if you can get it
I'm not sure about using a 73-87 rearend....Is your burb leaf springs?
Geoff with a G
Old 05-12-2011, 09:52 AM   #5
Str8burban
Re: Brakes and lugs
no it is coil springs. I have no problem keeping the rear end, just trying to figure out how to put new style wheels on old style drums....
Old 05-12-2011, 10:02 AM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Brakes and lugs
I'm no wheel expert, so you'll need to do your homework on the backspacing and what can be used......just FYI...I picked up a complete front and rear suspension from a 71 truck for $150.....so keep your eyes peeled for deals....also watch the parts board...folks part trucks all the time.....by chance is member 'teeitup' close to you? he ususally has some suspension stuff
Geoff with a G
Old 05-12-2011, 10:05 AM   #7
Str8burban
Re: Brakes and lugs
not sure, I am in central MO. I will see if i can figure out where he is
Old 05-12-2011, 10:09 AM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Brakes and lugs
he's in Meridan, KS....looks to be 4hrs away
Geoff with a G
Old 05-15-2011, 11:26 AM   #9
AzDon
AzDon's Avatar
Re: Brakes and lugs
If you want five spoke wheels, you will need to convert. Almost any other style wheel is manufactured in both six and five lug. As for fit, a 14" alloy rim will usually fit front drums, but would NOT fit over disc calipers.
Lowered spindles are only available for disc brakes, but you can choose five lug or six lug rotors if you do the conversion with a new aftermarket kit.
My burb had the 71-72 suspension swapped in when I got it, so I have five lug rotors in the front. I like my 3.07 twelve bolt rear and wide 4wd ralley wheels in the back, so I'm in no hurry to convert the back to five lug
AzDon is offline   Reply With Quote
