Old 05-11-2011, 07:34 PM   #1
aspiringthomas
aspiringthomas's Avatar
side mount gas tank 60-66 chevy truck
Has anyone done a side mount gas tank install. How many gallons do they hold. I have seen some retrofit in old trucks. I would like to move my tank out of the cab but look at options other than at the rear of the truck between the frame rails. I had thoughts about mounting a spare tire at the rear underside of the truck.
Thanks Jeff.
aspiringthomas is offline   Reply With Quote
Old 05-11-2011, 08:24 PM   #2
PGSigns
PGSigns's Avatar
Re: side mount gas tank 60-66 chevy truck
The way the cab is done and as little room as there is under the bed floor I would expect the tanks would be small. i had trouble getting the air tank under mine.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-11-2011, 09:13 PM   #3
jj1965
jj1965's Avatar
I looked into this alot and couldn't find anything that would work. Maybe build a custom tank? If you decide to do something different the gas tank from a 68-72 A body mounted in the rear works great.
jj1965 is offline   Reply With Quote
Old 05-12-2011, 11:23 AM   #4
jimmydean
jimmydean's Avatar
My truck has a small side tank on the drivers side that fills from the wheel well. I am using that same location to put my fuel cell and will do a proper filler. The one in there now isn't very big and has no sender. I've never used it since it seems to be solid rust.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-11-2013, 10:12 AM   #5
aspiringthomas
Thanks Jeff.
I did some calculations and I believe that if I build a tank that goes under the cab and bed it would hold up to 20 gallons.
Old 03-12-2013, 01:17 PM   #6
koda360
koda360's Avatar
At rear of truck, between frame rails is safest place for it.... why do you want to sit on top of 20 gal of BOOM, and try not to get into a wreck? All that for a spare tire? Thats what AAA is for...
1960 C-10
2000 Dakota R/T
1966 Fury I 2dr post
1984 Big Bronco
2002 Durango SLT (Bride's Ride)
koda360 is offline   Reply With Quote
