Old 05-11-2011, 07:51 PM   #1
dos0711
dos0711's Avatar
Wood Bed question...
Am I missing a couple of cross supports where the red arrow is? If so, is there anything else missing? Yeah, I know...the wood.
dos0711 is offline   Reply With Quote
Old 05-11-2011, 08:44 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Wood Bed question...
looks like two are missing
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 05-11-2011, 09:33 PM   #3
1low
that small one needs to come back to the first arrow
1low is offline   Reply With Quote
Old 05-11-2011, 09:46 PM   #4
dos0711
dos0711's Avatar
So basically I need two of the "regular" supports after I move the small one back?
Old 05-11-2011, 10:01 PM   #5
1low
Long box should have 5 of the bigger crossmembers
Old 05-11-2011, 10:03 PM   #6
dos0711
dos0711's Avatar
It's not a long bed...it's a short bed stepside.
Old 05-11-2011, 10:30 PM   #7
Tim R
It looks correct to me my short step is set up just like that
Tim R is offline   Reply With Quote
Old 05-11-2011, 10:32 PM   #8
1low
oh... someone might know better but i think that small one just needs moved back sorry for the confusion
Old 05-11-2011, 11:02 PM   #9
Tim R
The two spots you are pointing to you just use big fender washers on the bottom of the wood. I have a zinc plated bolt kit for a short step bed if you need a bolt kit .I well sell for 30.00 shipped if you need it . I changed to a polished stainless hidden bolt bed strip kit.
Old 05-12-2011, 08:16 AM   #10
dos0711
dos0711's Avatar
Anyone willing to crawl under their truck and snap a few pics for me?
Old 05-12-2011, 12:53 PM   #11
RenoKeene
Florida Edition
RenoKeene's Avatar
4 big ones for your short step. The small one bolts to the wood for reinforcement. Check the LMC cataloge on line...very good picture of this setup.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-12-2011, 01:02 PM   #12
RenoKeene
Florida Edition
RenoKeene's Avatar
Here ya go. Page 30
Also attached the bolt locations for you.
Brad
Old 05-12-2011, 01:10 PM   #13
lakeroadster
Here's what mine look liked after I removed the wood. Short Step 67-72 style. I was told it is missing a tall cross sill.
Evidentally though that sill wouldn't bolt to the frame... 'cause just like yours there are no holes in the frame for that cross sill? Seems strange to me. It's all good. I put a custom pressure treated plywood floor in mine... put the cross sills back just like I found them.
lakeroadster is offline   Reply With Quote
Old 05-12-2011, 01:14 PM   #14
DorianB
DorianB's Avatar
My truck was missing those two also, so I am going to go with they aren't supposed to be there.
It looks like you could put two more of the skinny braces in there though...
DorianB is offline   Reply With Quote
Old 05-12-2011, 01:23 PM   #15
lakeroadster
Agreed. Right in this thread we have (3) trucks that are all the same, yet don't match LMC's diagram....
Old 05-12-2011, 02:05 PM   #16
dos0711
dos0711's Avatar
I wonder if the LMC diagram is general in nature and meant to cover long and short stepsides...
Anyway, Awesome shots of the underside and such. Much thanks! Someone took this truck apart and I'm trying to put it back together again...lol
Old 05-12-2011, 02:13 PM   #17
lakeroadster
Yes the LMC diagram is generic, applicable to long and short bed trucks. That is why under quan. for the cros sills it shows A/R (as required).
Old 05-12-2011, 02:29 PM   #18
DorianB
DorianB's Avatar
I have a few more pictures I took of my bed when I was taking it apart, I'll put up a link...http://s340.photobucket.com/albums/o...rianbrytestar/
Old 05-12-2011, 02:30 PM   #19
dos0711
dos0711's Avatar
That would be awesome!
Old 05-12-2011, 02:53 PM   #20
lakeroadster
Thought I would browse some threads for other short bed photos.
Here are a couple short fleets, with the same cross sill configuration we have too.
Old 05-12-2011, 03:25 PM   #21
RenoKeene
Florida Edition
RenoKeene's Avatar
LMC probably is wrong, although there is 8 bed to frame carrige bolts in the kit I bought. I have a pre-drilled set of wood from bedwoodandparts.com in my living room so I'll count the holes when I get home.
Old 05-14-2011, 06:55 PM   #22
lakeroadster
Your are good, as is! I sent an email to tech. support at Mar-k stating the following:
To: Tech Support
Subject: Cross Sills
Would you have time to help with a question? I have a Chevy '67 short stepside, see attached a photo.
I am being told that I am missing some cross sills. I don't think that is true. What is the "factory correct" configuration for a shortbed stepside in the 63-72 design.
Thanks for your help.
John
Here is their response:
John:
I asked the engineer to look at your picture and this is his response:
He is not missing any cross members. All that I see that is wrong is the placement of the reinforcement strip. It should be just before the third cross sill, after the frame arch. His is before the frame arch and too close to the #2 cross member.
Thank you,
MAR-K Quality Parts
6625 West Wilshire Blvd.
Oklahoma City, OK 73132
Phone 405-721-7945 (8-5 Mon-Fri. CST)
Fax 405-721-8906
http://www.mar-k.com
So to summarize, the short beds are supposed to have 3 cross sills, 2 in the front and 1 in the back, and (1) reinforcement sill.
