alternator problem's
I never had trouble with my Alt. until I got my stereo system put in about a year and a half ago. Since then I have gone through two. Before I go down and get a new one is there a larger amp one that I can get instead of the the 62 amp or what ever it is that is a direct replacment? Its a 1971 half ton with a 350. Would changing the voltage meter help any?
Thats the Hillbilly way
You may want to do a search on installing a single wire alt.
or try this outfit http://www.alternatorparts.com/gm_al...grade_kits.htm
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Do you still have the external regulator? If so I would look at upgradeing that to the internal alternator. I did this about two months ago and could not believe the difference it made, I also went with a brand new power master 140 amp alt. But if you going to keep the old external set up, just go to a place that you can get a new one from, I have bought alternators from Autozone in the past that were bad right out of the box. Matter of a fact that has happened to me twice. Had them check it out right out the box and it was no good.
Sam
72 LWB chevy truck. Pasadena, Texas |
Yes, there are larger amp alternators. Just ask. If you have trouble, tell them your 71 comes with A/C and that will make the 80 amp pop up on their screen. Usually they have options, but you have to pay more for more amps. As Sam mentioned, you can get alternators that are much, much larger if you want.
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
CCRider
Must be one bad@ss stereo...lol. If you go with one of the really big alternators you need to replace the wire from the alternator to the battery as the stock one can't handle 140 amps
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
