05-11-2011, 08:05 PM | #1 |
starter issues
okay so the starter on my sb 350 made a hell of a noise, i took it off and grabbed the one of my spare motor i put it on and a shim that came off the old one went to start it same horrible grinding noise WHAT DID I DO WRONG obvioulsy not a direct bolt on part never had to change a starter befor HELP ME PLEASE!!!!
05-11-2011, 08:22 PM | #2 |
What Hump?
Re: starter issues
When you say horrible noise, be more specific. Is making a loud grinding like the teeth are not lining up or is it trying to turn over and grinding at that point?
Tom
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
05-11-2011, 08:34 PM | #3 |
Re: starter issues
Busted flex plate? That would be horrible. Been there, done that.
05-11-2011, 09:28 PM | #4 |
Robert Olson Transport
Re: starter issues
see if you can roll the truck up a few feet and try it that should help rule out the flex plate.. bering broken.. did younotice if the teeth were ok on the flex plate?
05-12-2011, 02:45 AM | #5 |
Re: starter issues
The teeth are grinding, I'm going to take out the shim and roll it forward a bit I layed under when buddy tried starting it and its not lining up
Posted via Mobile Device |
05-12-2011, 04:47 AM | #6 |
Re: starter issues
Is the Flex plate worn, are the teeth in bad shape. Is the starter bindex not pulling out far enought. Have you tried painting the flex plate with spray paint to see where its clashing.
05-12-2011, 05:30 AM | #7 |
Re: starter issues
You can see on the flex plate were it is hitting it all the teeth are fine and the gear In the starter comes out far enough it just makes one heck of a grinding noise do I have to line it up some how should I take the shim out and see what happens what's the worst I could wreak I have a complete parts truck not to worried
05-12-2011, 07:17 AM | #8 |
Re: starter issues
All of the mechanics I have talked to about starters have told me that they have never used shims when installing starters, which makes me wonder why the shims are included with a new starter. Sounds to me like a bad starter, not extending far enough to completely engage. I have never had much luck with rebuilt starters, so I finally bought a GM high torque mini starter which has worked very well. The only thing I don't like about it is that if the truck does not start on the first attempt you have to wait a few seconds until the starter winds down before starting it again.
05-12-2011, 07:41 AM | #9 |
Re: starter issues
Shimming a starter properly makes a difference. There should be a gap between the flexplate and the bendix for proper engagement.
http://www.superchevy.com/technical/...ing/index.html http://www.marinemechanic.com/site/page169.html
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
05-12-2011, 12:55 PM | #10 |
78K & 79C Jimmys
Re: starter issues
mine was grinding and it was the flex plate and starter
both were worn quite a bit try using the starter outa the truck with booster cables make sure it comes out and turns freely do it quite a few times
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
