05-11-2011, 08:29 PM | #1 |
Radiator Question
Hey Guys what Radiator are you guys using in your 64',65',66 I have a 64 GMC it had a Buick 350 in it and I recently put a 350 crate motor with a 700R4 my current Radiator leeks and was not the factory one so I looking to replace it What is everyone using
05-11-2011, 08:33 PM | #2 |
Re: Radiator Question
Do you have access to a factory original,,, mainley for the tanks itself, then have it recored, or buy from summit (aluminum) that would be you next best bet...and you`ll need a shroud if you don`t have one.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
05-11-2011, 08:49 PM | #3 |
Rich
My only consern is I don't know what the P/O took out of the truck for mounting hardwhere and would it matter if the truck had a 6 or a 8 cyl in it, for the factory style set up |
05-11-2011, 08:53 PM | #4 |
Not sure what style rad mounts GMC used, I`m sure someone here will jump in,
05-11-2011, 09:06 PM | #5 |
I am using the factory three core radiator no issues. Bought it new at Autozone, I did add a tranny cooler for TH-350 because of the stall in the converter. My truck has two mounts on bottom with rubber inserts and one behind the hood latch. Cools my 350 with ac just fine.
05-12-2011, 09:12 AM | #6 |
Greshampiglet:
I went through this in a panic a few months ago. Radiator shop couldn't get new core to fix my old one. Radiator shop wanted $500 for a "custom" manufactured replacement radiator. No thanks. Radiators on E bay were $225, but were aluminum from China. No thanks. I found a new copper/brass three row radiator for $186.79 from Rock Auto (www.rockauto.com) supplied by Proliance, made in Mexico. Ended up $207 with shipping. The radiator has connections for auto tranny cooler that I didn't need and was slightly larger on the outlet then my original (1.75" vs. 1.5"). I am well satisfied. One note on measurements that I learned is that they don't include the tank. You need to add the tanks to get overall dimensions. Here is the info from the Proliance site and the part number for it: Regards, Steve New Orleans Part Number - 433284 Make - GM Construction Copper - Brass Core Size - 17 3/8 x 24 3/4 x 2 Number Of Rows - 3 Mount Type - Channel Inlet Location - Top Left Outlet - 1 3/4 Outlet Location - Bottom Right Tank Inlet Size - 2 1/2 x 25 7/8 Tank Outlet Size - 2 1/2 x 25 7/16 Hose Inlet Size - 1 3/4 Transmission Oil Cooler - 1 |
05-12-2011, 03:15 PM | #7 |
Just put one in my daughters 60 yesterday I bought an alum
One from jegs but I had to weld some agle on each side and drill holes to match the original bolt holes cost me 150 way to go if u can weld alum or know some one who can I will post some picks next week I'm out of town until next Tuesday My truck has a 283 radiator is a generic 4 core a bit smaller than the original But it will b more than enough Posted via Mobile Device |
05-12-2011, 03:39 PM | #8 |
1965 Chevy C10, 2005 4.8L/4l60
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-12-2011, 04:21 PM | #9 | |
I'm all for modifying stuff when it makes sense but on this one I gotta agree with jj1965 and slorio. Why reinventing the wheel, going with aluminum and modifying brackets and components to get it to fit when there are direct bolt in OEM types for less money? Last edited by lakeroadster; 05-12-2011 at 05:09 PM. |
05-12-2011, 05:03 PM | #10 |
I didnt modify anything, I just pulled the old one, dropped this one in, attached the elect fans and filled it up.
05-12-2011, 08:22 PM | #11 |
Looks like putting a stock replacment is the way to go, the one that was in the truck with the Buick motor i'm pretty sure was out of a car, looks like finding one at at wreacking yard is gooing to be a tough find thanks for the links guys
GreshamP1GLET |
05-12-2011, 11:23 PM | #12 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
I bought a champion aluminum rad off of ebay with the eletric fan and shroud for my street truck and it bolted in easy ,fit great and works awsome. I like it so much I think I will buy one for my prostreet truck but the next one will have dual fans in it.
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
