Brake line help
Alright i had a set of extended brake lines that came with my truck. I put 3/4 ton axles out of a 78' in it so the lines didn't fit. I drilled them out so they would accept the banjo bolt hoping it would seal......well it didn't. I need to know where the cheapest place for one and what brake lines i should buy? Do i get the "heavy duty" ones or just the reg 3/4 ton? What one has the bigger bolt? I know the 78 and older have a 7/16 bolt but how do i know what lines to buy? If anyone could point me in the right direction that would be great!!!!
![]() Join Date: Feb 2010
Re: Brake line help
You mean the flex lines that go to the caliper? Did you look at Summit? Stainless Steel Brake Corporation (SSBC)? EBC Brakes?
Re: Brake line help
yeah the flex line.....i know a lot of placs to buy now just need to know if i need the "heavy duty" or the "reg" my bolt is 7/16 like i said so its bigger but pre 78 was bigger so just not sure.
