Home Built '87
12 Bolt Rear axle gears a bit rusty
I found a 12 bolt rear end with a posi...needs new brakes of course!
But it has some rust inside the housing....any tips on how to clean it up or just run it for a day with gear oil then completetly change the gear oil out with new stuff and should be good??? Any other methods out there?
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
Re: 12 Bolt Rear axle gears a bit rusty
Eww, grenade lock!!!! Put oil in it, run it, then change it. The grenade locker will give out before anything happens with the gears.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
18 Till I Die
Yup run it then change oil
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
Happy to be here
![]() Join Date: Mar 2000
Rinse it out completely thinner first. If it doesn't have one, I would epoxy a magnet on the inside bottom of the cover. Run it a little and pull the cover. Clean the magnet, add fresh oil and move on.
Happy to be here
I know the Gov-Loc is weak, but they aren't as bad as you make it sound. My guess is thats a 70's axle, and its lasted this long.
Junior Member
with no horsepower and no tires they will live. Get the RPM's up and then the centrifical weights kick in and it gets ugly. But heck, I would run it till it fragged too.... you never know. Just depends on how you drive it.
Home Built '87
Well, I had an Auburn put in my '98 for $1,000 last year....I thought for $150 plus the cost of brakes I will go with this setup until it blows.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 Last edited by Gordonr1973; 05-13-2011 at 12:10 AM. |
#8 | |
Junior Member
Exactly ..... then IF and WHEN she lets loose, look into the Eaton Tru-trac. I have had exceptionally good luck with these units. Especially if your not wanting to go full locker/ spool. |
Home Built '87
Maybe. As long as they are quiet I will consider it. I put a Detroit Locker in another '98 I had and I had to pull it. The noise drove me crazy!
Happy to be here
Very good idea. As mentioned they aren't the strongest unit by design, but for a buck fitty, go for it.
