05-11-2011, 10:29 PM | #1 |
Spare Tire Question
What are you guys (and gals) doing with your spare tires? With every truck I've ever owned, when I need the spare tire that was stored under the bed, everything was rusted and I couldn't get the darn thing off.
As a result, I haul the spare around in the bed, which is a less than ideal solution. Any suggestions?
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
05-11-2011, 10:49 PM | #2 |
Re: Spare Tire Question
If your running good tires chances of needing a spare are slim. I have not had a spare in my 72 for over 10 years. Knock on some wood. I do have AAA.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
05-11-2011, 10:52 PM | #3 |
there was a in box spare tire carrier that bolted the tire to the drivers side near the cab here is the mount in this pic with out the bolt that holds the wheel I have never seen what it looks like cause it was gone befor I got the truck.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
05-11-2011, 11:34 PM | #4 |
Good thread, I also have my spare tire just sitting in the bed. The previous owner did give me the under bed mount, but it's so rusted, it looks dangerous to mount a spare tire on it.
Thanks, Emil 1972 Chevy C20 |
05-12-2011, 12:23 AM | #5 |
Looks good at 20-ft .....
"Got spare?"
If you got it, flaunt it. Only stepside-lovers know the joy. |
05-12-2011, 08:11 AM | #6 |
One of the best solutions is----well let me start with what many guys have done--they removed the fuel tank from the cab and put a blazer tank under the rear of the bed--pretty much bolts up with modification for the filler. So no spare there--. If you get your hands on a surburban spare tub or take a regular fleetside rear tub and invert it--you can mount your spare behind the drivers side and install the tub through the floor of the fleetside bed between the rear wheel tub and the front of the bed. This custom work allows the spare to be mounted below the top of the rear quarter so it's not sticking up. The end result is really pretty neat.
05-12-2011, 09:15 AM | #7 |
since i get a whopping 6 MPG, i dont go far enough from home to worry about a spare.lol
In the words of my favorite poet, singer/songwriter (Paul Thorn):"What ever you believe, you might be wrong" |
05-12-2011, 10:24 AM | #8 |
Between Trucks...
I got a repop underbed spare tire carrier from LMC. A little antiseize and you shouldn't have to worry about rust. They're probably available on the parts board too.
Beat it to fit, Paint it to match... Last edited by Sinister; 05-12-2011 at 10:25 AM. |
