Old 05-12-2011, 02:30 AM   #1
rcbildr
rcbildr's Avatar
Header Question
I'm hoping to use a set of headers (unkown brand) that came off a 78 camaro. Will I have any problems getting these to fit? Any help will be greatly appreciated. Thanks!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 05-12-2011, 09:38 AM   #2
dougo
dougo's Avatar
Re: Header Question
Not sure if you would have problems getting them to fit (unless they are warped at the flanges). But if they are an off brand or inexpensive header you could run into chronic exhaust leaks - from my experience. I've seen success with good quality headers.
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
