05-12-2011, 08:55 AM | #1 |
Turn Signal Question
Ok guys here is what I have. I am trying to fix all the little problems the old truck has. When I got it the turn signals didnt work. I changed the flasher and checked the fuses. Emergency flasher works fine. When I turn on the left or right turn signal I get nothing. Every other light on the truck works. Including brake, headlight, parking light, etc. When should I go next.
1970 Chevy Stepside, 350/ 350 Turbo 1967 Chevy Shortbed, 454 CI, 700R4, currently work in progress. Check out the build up at http://www.cardomain.com/ride/2933497/1. http://67-72chevytrucks.com/vboard/s...d.php?t=264458 1957 Chevy 3100 Stepside Truck. All original for now. |
05-12-2011, 01:28 PM | #2 |
Re: Turn Signal Question
test the turn signal switch. There will be a plug on the column that you can put a test light on to tell if the switch is sending power to the flasher or if the switch is even getting power.
05-13-2011, 05:55 PM | #3 |
Ok I took a peek under the dash before the rain storm today. I found some melted wires going to the backup light switch. Not sure why. There is a box under the steering column that has a heat sink attached to it. What is that for? I did not get to the turn signal yet. It came a down pour and had to come in for a while.
05-13-2011, 06:45 PM | #4 |
God is good!
If you have a test light you can check if there is power going out to the bulbs. If there is power there, you likely have a ground issue. On the older trucks, the ground is on the housing itself. There are a few good threads around here that have similar issues.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
