Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Crew Cab rocker panels
I hate to admit it but I havent had much luck finding replacement full length rockers for my 85 Crew Cab. Can someone share a link or point me in the right direction? Thansk guys.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Re: Crew Cab rocker panels
LMC has the crew cab rocker panels.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=27 A lot of people say not to buy from LMC but I bought a rocker panel from them last week and it was fine. The only problem I had was they never did email me that my shipment went out till after I had got the part. I was going to get one of the crew cab rocker panels, but decided i didnt need the whole panel so I just bought one for a regular cab. Btw, I like the crew cab you picked up, is it a auto or manual? Matt
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
The one I got is a manual. It will either get a 700r4/np205 or I will just do a Cummins or Duramax and overdrive auto trans. I kinda like the 6.2 though. I have heard so many bad stories about LMC parts I am kinda afraid to use them. I want the entire rocker for both sides!
Ive got a 6.2 for my truck but have yet to fire it up. Cant wait to see what it does. I have never seen the whole rocker. That is the only crew cab rocker I have seen.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread Last edited by Mattman2010; 05-12-2011 at 03:00 PM. |
My buddy ordered a bunch of parts for his blazer and recieved them 2 days later. I have had nothing but good experiences with them.
We sell the sme ones as LMC. They are the slip on style same as theirs. $25.00 each
![]() Join Date: Dec 2010
LMC is great, not sure why so many dislike them... Only thing about them is that they are generally a little pricier than some of the competition, but from what I have seen from them it's all really high quality stuff.
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
Well I ran into the same problem when I put them on my dually. There are a full length slip on rocker that in my opinion look like crap. The front rockers are the same as a regular cab truck. The rears are a little more complicated because I havnt been able to find the correct one. The rear part is the same as the regular cab, but the front part is compleatly different. So the only thing I could do was cut the old one along the flat part that would be hidden by the door and weld it together. I was lucky that my rockers wernt TOO bad that I could do that. Actually I didnt know they were that thin till I started sanding the truck down. Just another note that the cab corners are the same on crew cab to regular cab too if you needed them.
1984 K20, will rebuild as a tribute truck to my high school 82 K20 1986 ElCamino (needs motor) 2004 2500hd LLY duramax |
I definitely don't want the slip on style. Looks like I can just buy four regular cab rockers and go to town...
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. Last edited by STOCKISH; 05-14-2011 at 09:04 AM. |
| Bookmarks |
