05-12-2011, 03:36 PM | #1 |
69 GMC radiator question
Took the truck for a ride and notice after few minutes on the parking lot , that was water leaking from the radiator ( the hose conected to the top )
open the cap and really the water is there,,,maybe 2 inches under the cap Any idea? The engine did not over heat is that normal ? ty |
05-12-2011, 04:20 PM | #2 |
Re: 69 GMC radiator question
If its leaking, its not normal. Id replace the radiator hose and see if that doesnt help. It may not be overheating now, but you dont want to be stuck in traffic on a hot day with a blown hose or water pump.
05-12-2011, 04:23 PM | #3 |
That's normal. It finds it's own level. Enough for expansion.
05-12-2011, 04:34 PM | #4 |
well the radiators look fine
not even getting hot,,, |
05-12-2011, 04:42 PM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
it is normal, the fluid only needs to cover +1" over the coils in most cases. a little expansion room is good. also condensation will come out of the overflow tube if real cold or hot outside.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-12-2011, 05:36 PM | #6 |
Thank you
was running dripping for maybe 5 minutes,,,enough to make a mark on the driveway could say a good beer cup will keep eye on |
05-12-2011, 05:40 PM | #7 |
When it finally stops dripping check and see what the level is. Keep it full to that point.
05-12-2011, 08:28 PM | #8 |
Good looking GMC!
If it bothers you it is easy enough to install an overflow tank. As has been mentioned it is normal for the radiator to spit some fluid out if it is over filled. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
