Old 05-12-2011, 06:44 PM   #1
ubtripn
ubtripn's Avatar
LMC Mirrors, Left one sticks out farther than the drivers side?
As the title states the passenger side sticks out farther - is this on purpose? The single bent rod is welded are place and not adjustable, I was just hoping it was so you could see it better from behind the wheel. These are the rectangle ones from LMC. Anybody else ever bought these?
Name:  2011-05-01 12.48.42.jpg
ubtripn is offline   Reply With Quote
Old 05-12-2011, 08:01 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: LMC Mirrors, Left one sticks out farther than the drivers side?
I believe that's the reason. My stock round (peep) mirrors are different sized.
Passenger side is about 10" long and the driver side is about 9".
68gmsee is offline   Reply With Quote
Old 05-12-2011, 08:05 PM   #3
99-LS1-SS
99-LS1-SS's Avatar
I believe the size difference is intentional. The logic is the angles that you look through the mirrors at is different so the passenger's side needed to stick out a little further than the driver's side. Plus the bottom of the mirror needs to clear the door at the bottom of the passenger's window so the door doesn't obstruct the view.
99-LS1-SS is offline   Reply With Quote
Old 05-12-2011, 08:40 PM   #4
ubtripn
ubtripn's Avatar
Cool, thanks guys.
Old 05-12-2011, 08:43 PM   #5
ubtripn
ubtripn's Avatar
Were the stock trucks like this?
Old 05-12-2011, 08:46 PM   #6
chewychevy67
my truck has the original mirrors and arms and they are the same as yours.
chewychevy67 is offline   Reply With Quote
Old 05-12-2011, 09:54 PM   #7
cadillacart
1972 C/20
cadillacart's Avatar
I have the same mirrors and I noticed the same thing. Must be intentional.
My Gallery
1972 C/20 402
Gramp's Truck
cadillacart is offline   Reply With Quote
Old 05-12-2011, 11:04 PM   #8
ubtripn
ubtripn's Avatar
Good deal, glad its on purpose but so much for evenness.
Old 05-13-2011, 01:17 AM   #9
ace of shades
NEWBIE!!
ace of shades's Avatar
I ran into a problem, while working on a 66 Buick, while using a drivers side mirror on the passenger side. You can't see **** from the drivers seat. The mirror doesn't come in far enough to see down the car, and even if it did the positioning of it would put the mirror's face right dead square with the quarter window trim.
I don't know if it would be the same for the truck, But I have heard the same *****es with aftermarket mirrors on the 73 and up chevy's
Water is for the weak
I don't like cocaine.. I just like the smell of it
"Well there might be a dime up a goats ass too, but I ain't looken" - Grandpa
VolksRods
ace of shades is offline   Reply With Quote
Old 05-13-2011, 05:25 AM   #10
Sicklajoie
The Niner
Sicklajoie's Avatar
That's why I have the little convex blind spot mirrors along with my regular mirrors. You can't see squat with just the regular mirrors.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 05-13-2011, 09:40 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Yup... as I mentioned, mine are stock.
Old 05-13-2011, 10:23 AM   #12
ubtripn
ubtripn's Avatar
thx
Old 05-13-2011, 10:31 AM   #13
68gmsee
Active Member
68gmsee's Avatar
Did the mirrors mount to the original mount holes? I've thought of buying the larger ones for my truck.
Old 05-13-2011, 10:59 AM   #14
ubtripn
ubtripn's Avatar
perfectly
Old 05-13-2011, 03:19 PM   #15
nightmare
nightmare's Avatar
Are there any vibrations when driving down the road at 70? I've got the dumbo mirrors and they vibrate and shake like crazy. Drives me nuts (no pun intended). I'm wanting to replace them with some like this.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-13-2011, 04:35 PM   #16
cdowns
cdowns's Avatar
every truck i've had the drivers side has been on the left
Old 05-13-2011, 05:12 PM   #17
Mike J
vw guy & now c-10 guy
Mike J's Avatar
^ lol
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 05-13-2011, 06:49 PM   #18
cadillacart
1972 C/20
These shake like crazy.
My Gallery
1972 C/20 402
Gramp's Truck
Old 05-14-2011, 08:18 AM   #19
ubtripn
ubtripn's Avatar
yeah, they shake, only way around it would be another metal support rod or the three rod support mirrors. Bothers me too.
Old 05-14-2011, 09:40 AM   #20
68gmsee
Active Member
68gmsee's Avatar
cadillacart ...These shake like crazy.
Thanks for the warning. If the larger ones shake, probably can't see out of them since I drive on a lot of bumpy roads. I guess I'll keep my round ones. They're pretty solid.
Old 05-14-2011, 01:23 PM   #21
cdowns
cdowns's Avatar
i wonder if you fabbed up backing plates and used nuts and bolts to secure mirrors if you might b able to eliminate some of the vibration problem with those mirrors
Old 05-14-2011, 01:47 PM   #22
ubtripn
ubtripn's Avatar
I used the original mounting plates, lock washers and nuts, super tight. The arms are just too long. It doesn't do it too bad.
