03-28-2003, 01:16 PM | #1 |
Seņor Member
air switch boxes
Re: 1/2" Parker Air Valves for sale
quote: -------------------------------------------------------------------------------- Originally posted by fastbagged68 www.excentrixauto.com -------------------------------------------------------------------------------- I surfed over to this place and saw their switch boxes... they don't have any real descriptions of any of their stuff. If anyone knows... does the 5-switch box do 4 corners independently plus a master up/down? What about the 7 and 9-switch units? What's on the other end of their logic circuit (I'm ASSuming they're using some kind of logic circuit and not just a bunch of messy relays and diodes)? Bare wires that run to the solenoids? Anyone ever used one of these controllers? It might be a solution to my dash dilemma... I could just toss the controller under the seat or something. Kenneth
03-28-2003, 05:55 PM | #2 |
L.E.D. Freak
XXL I have devised a ash tray switch box using Carbon Fiber board. You can cheaply and easily make your own using I perfer Momentary push button switches. And some diodes. Radio Shack. I curently only have rear bags but I have three functions. Independant control over bothe rear bags, and both rear bags fill and both rear bags dump. Very easy. Call anytime tonight if you have questions on how to set this up.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
03-28-2003, 06:48 PM | #3 | |
Seņor Member
And I saw your thread and pics on the ash tray switches. Unfortunately, I have a problem using something like that... Kenneth
03-28-2003, 07:27 PM | #4 |
If you really want some cool switches and a effient air managment system check this out www.accuaircs.com or www.accuaircontrolsystems.com I can get these.
03-28-2003, 08:45 PM | #5 | |
Seņor Member
Kenneth
03-28-2003, 09:17 PM | #6 |
L.E.D. Freak
XXL We're on the same page here. Low budget!! LOL But nice.
Ok this is what I'm into... I'm making a custom center consol to house 4 gauges, and my B&M Mega Shifter. And a TV VCR for the back seat riders. XXL you could implement a custom center counsol with hidden switchs, and ultra bright White LEDs to illuminate the 4 gauges( which are cheap white face 7.00 each gauges! LOL ) in it cheaply. Like I said Very cheap. Like less than 30.00 total for full control. Front /back /side to side/ three wheel motion/pan cake 4 up/pancake 4 down. The works. Cheap no B.S. Also I'm working on a spring set-up to pull the a-arms up! It'll be trick. Call me. Anytime tonight or after 4:30 eastern tommarrow.
03-28-2003, 10:23 PM | #7 |
Seņor Member
I have this now (with a 5th switch in my dash bezel)...
I'm going to have to hide it all (and more-- headlight, wiper, ignition, etc.) to maintain the smooth look. I was not planning on a console (also part of the smoothie-rod) look... just stock bench reupholstered. However... I may have to be a little flexible somewhere as I've got too much stuff I need to find room for. So I may do a small console, but it will definitely have to have a trap door to hide everything when not in use. Kenneth
03-29-2003, 01:47 AM | #8 |
XXL, If it's a truck, you can get the formed headliner with the speakers molded in. It's plastic so you can add all the gadges and switches you want. The will be accessable, but up and out of normal line of vision. Just a thought.
03-29-2003, 06:44 PM | #9 |
L.E.D. Freak
Yeah I like to hide things to. Are you planning on Carpeting the dash? Or some material? Maybe in your case a switch box would be best. Slide it right under the seat. But I still think making your own would be easy.
03-29-2003, 08:08 PM | #10 | ||
Seņor Member
Kenneth
03-30-2003, 01:26 PM | #11 |
My Thoughts Exactly!
as far as I know like any other hack shack product there is no logic or even relays..just the switches wired to the valves. I would stick with your ridepro panel and just hide it or cut it in half and put the gauges somewhere and then you could mount the switch panel to a small electronics project box and stash it under the seat.
03-30-2003, 01:32 PM | #12 |
its all about the +6 inches
As for running the wires up to the top of the cab, you can run them up the back wall. It'll take some fishing, but they can be routed up that way.
03-30-2003, 01:59 PM | #13 |
chevelito
sup kenneth,
my creative juices arent flowing yet this early in the morning. Weren't you going with a new steering column with wipers and ignition on it? anyway, i thought you had come up with a linear actuator to bring the guages and switches down from the dash? jay
New deadline...when my son can drive. Aloha from Honolulu, HI |
03-30-2003, 02:18 PM | #14 | ||
Seņor Member
Kenneth
03-30-2003, 02:27 PM | #15 |
L.E.D. Freak
If you want to easily fish the wire through the back of the cab, just take out the interior light and use the harness from that to fish them up to the interior light. Just have to run 1 pull wire with it. This is how to fish the third brake wire I make on our Cargo/third brake insert.
All thats in a switchbox/or at least need to be are the centering/momentary switches and diodes. Eventualy I want my bags tied into the ignition, and a wireless remote.
03-30-2003, 11:47 PM | #16 |
chevelito
sup kenneth,
none of the custom column manufacturers like flaming river etc have one with both wipers and lights etc? jay
03-31-2003, 12:12 AM | #17 | ||
Seņor Member
I have been discussing the issue with a place called Columns Galore. Here is their most recent response. I'm still waiting on some more solid info-- dimensions, etc. Quote:
Kenneth
