Old 05-12-2011, 11:36 PM   #1
Brewski*
Brewski*'s Avatar
Holly Off Road Avenger Installed. What a difference~!
I opted for the Aluminum 670cfm model and was a little skeptical. After installing it there were a few issues. All my bad~! Hooked the vacuum lines up wrong and the old carb springs were week. Now that it is installed correctly it really is wonderful compared to the Rochester and the Edelbrock 1406. The Edelbrock was good off the line and out of the box it did not run correctly on my truck at altitude of 6k. It took lots of adjustments and a supply of needles and jets to run at different altitudes and never ran right at all off road even after adding the springs. The Rochester was fine off road but was old and needed the throttle plate bushing kit installed as there is slop there letting air in so it does not idle well and has a float sticking or something causing gas to run over. So I went on a test drive with everything working properly and WOW what a difference. Starts IMMEDIATELY and correctly. I just barely bump throttle and the choke kicks in and just a quick flip of the key and it runs. NEVER started like that with 3 other carbs. Flat out gets with it down the road and I have not even put in the performance spring in the secondaries. Going off road and mudding a little tomorrow after all the rain tonight. LQQK OUT~!
Brewski* is offline   Reply With Quote
Old 05-13-2011, 04:54 AM   #2
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: Holly Off Road Avenger Installed. What a difference~!
Good to hear!
For some reason I really want to try the summit brand carb they came out with a couple years ago. $230 for a 650 cfm electric choke carb doesn't sound to bad either!
It's always nice to get feedback on products like this. Thanks!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 05-13-2011, 09:02 AM   #3
Brewski*
Brewski*'s Avatar
230.00 sure sounds good but wonder if it made to go off road at all?
Old 05-13-2011, 09:30 AM   #4
fun in dirt
fun in dirt's Avatar
Glad you let us know about this. I wondered how they were.
I hate edelbrock carbs too, never had one that could get running really right.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 05-13-2011, 09:54 PM   #5
propanemudtruck
Yeah, not sure. It'll go on the C10 if I ever do get one. For now I'll be sportin the 2jet Rochester!
-Kevin
