05-13-2011, 01:13 AM | #1 |
sbc motor mounts
putting a 283 in my '63 ish short/step. saw a post from MARKEB01 titled,60-62 gmc to sbc motor and trans mnts. i have the same perches/towers for my truck,but i cant find motor mounts that are "post" style to fit them. anyone know where i may get a set. thanks in advance.
05-13-2011, 01:16 AM | #2 |
Senior Enthusiast
Re: sbc motor mounts
Is this what you're looking for? O'Reilly Auto part number 2282:
http://www.oreillyauto.com/site/c/de...2327&ppt=C0019 |
05-13-2011, 02:39 AM | #3 |
not sure. if a bolt goes in the big hole and thru the hole in my perch and it will bolt to my 283 then yes. sure looks like it. will give them a call. thanks for the help. looking forward to exploring this forum,seems like a good find. thanks again ron
05-13-2011, 02:47 PM | #4 |
Senior Enthusiast
Yes that is how that mount works. The hole in the middle is threaded and the bolt goes through the perch into the center of the rubber area. The item shown was the result of a search for a 1963 Chevy C10 with a 283.
There are several good Chevy truck sites on the web, but this one has the most active membership. It's a friendly place to be if you're looking for input from individuals with a variety of build preferences and specific areas of expertise. And welcome to the forum! Last edited by markeb01; 05-13-2011 at 02:48 PM. |
05-13-2011, 08:33 PM | #5 |
thanks again, was'nt even sure the mounts where available.
05-14-2011, 12:29 AM | #6 |
60-66 Nut
Welcome to the forum
The same motor mounts were used for the small block equipped trucks from '63-'72. Don't forget to use a good heavy flat washer on that 7/16" bolt that goes up thru the frame bracket and into the motor mount.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-14-2011 at 12:31 AM. |
05-14-2011, 12:32 AM | #7 |
I have car A.D.D.
I gotta get a set too. I just keep forgetting to keep my eyes out. Really should pay attention so I can work on getting my Burb running before next winter gets here.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
05-15-2011, 07:14 PM | #8 |
what thread is the 7/16" bolt?
05-16-2011, 01:02 AM | #9 |
60-66 Nut
It is 14 thread......7/16"-14 by about 1-1/4 or 1-1/2" long. You'll also need a good heavy flat washer. I would go with a L9 flat washer if you can find a couple.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-16-2011 at 01:02 AM. |
