Old 05-13-2011, 08:12 AM   #1
chevykevy
chevykevy's Avatar
Straight down Drop Rams Horns on 2wd?
I was told by a friend that when he went to an exhaust guy he was told that the straight drop rams horns were designed for the 4wd trucks and he needed to get the angled toward the rear rams horns for him to do the exhaust. I have had stock 2wd trucks with straight drop manifolds in the past that I believe were original.
I am planning on using rams horns on my current project. I can see how it may be easier for the exhaust guy to use the angled manifolds over the straight but should I be concerned about using the straight drop for any reason? I have a passenger side rams horn with the angle. Would it look stupid with one of each?
chevykevy is offline   Reply With Quote
Old 05-13-2011, 08:16 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Straight down Drop Rams Horns on 2wd?
If you have your engine in the Six Cyl holes they will work (just saw a truck yesterday like that) But, if you have your engine in the Eight Cyl holes it is a really tight bend that most exhaust shops wont try to make....(Been there done that).
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-13-2011, 08:26 AM   #3
chevykevy
chevykevy's Avatar
That explains it. I'll try to find the drivers side with the angle to keep it simple.
Old 05-13-2011, 08:32 AM   #4
OJ1988
Just a car guy
OJ1988's Avatar
Yep, I put a v8 in 6cyl mounts and had to use straight rams horns, angled ones hit clutch linkage.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 05-13-2011, 11:27 AM   #5
71meangreenc10
Got a new one from LMC.....
Smitty
71 C30 Wrecker
