Old 05-13-2011, 10:04 AM   #1
bguild
bguild's Avatar
Welding up cab air vents? should I or is there a reason not too.
question.. I have a 67 chevy and I am getting ready to do alot of cab work this summer.. My question is about the outside air vents that are in the kick panels of the cab. I was planning to weld them up and put speakers there.. I hate getting leaves and everything else in the cab. My other reason is that I will never ever use them. I plan to go with vintage air and I just wont use em. Is there a reason I should do this? Like rust etc.. Do I need to do anything to the outside part or do you think just make a nice patch to weld in the interior would work?
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 05-13-2011, 10:17 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Welding up cab air vents? should I or is there a reason not too.
I would think you'd be fine as long as you block off the entry passage. I'm sure someone else has done this and provide some more specific info.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 05-13-2011, 11:48 AM   #3
POPO1984
POPO1984's Avatar
I just welded a piece over the vent when I had my cowl off. I'm even thinking of welding up the cowl where the wipers are so that it is completely sealed up.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
