Old 05-13-2011, 01:05 PM   #1
ubtripn
ubtripn's Avatar
What tools do I need to...
Take off the side of the bed. See, I found a 68 that has almost pristine bed-sides and I can get tem for 75 bucks a piece. I am ssuming 9/16 to 5/8's but what else will I need. I have never pulled the bedsides off before. Thanks!
ubtripn is offline   Reply With Quote
Old 05-13-2011, 01:16 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: What tools do I need to...
a cutoff wheel. there are 2 small spot welds at the back by where the tailgate mounts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-13-2011, 01:22 PM   #3
ubtripn
ubtripn's Avatar
yikes, no outlets, better look for a battery powered one, would a metal chisel and hammer do it without damaging anything?
Old 05-13-2011, 01:24 PM   #4
leddzepp
Moderator
leddzepp's Avatar
I suppose you could try that too.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-13-2011, 01:25 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You will also need 1/2" wrench. 1/2" Socket, and wrench, Large Phillips screwdriver, and possibly a toarch. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-13-2011, 01:32 PM   #6
ubtripn
ubtripn's Avatar
Got it, thanks! Is the torch for the spot welds to heat up and then break?
Old 05-13-2011, 01:38 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
I found taking mine off that once you started loosening the nuts the carriage type bolts wanted to turn in the holes. Be sure and spray the threads with penetrating oil. It also helps if you clean the threads with a small wire brush after spraying them the first time, then spray them again. Yes, I know it is a pain in the arse, but it really helps in getting them off. Also, have someone in the bed holding down on the bolt heads. I have found that pushing down on the bolt heads with the handle of large hammer works well and it is easy to hang on to.
LockDoc
Leon
Old 05-13-2011, 01:49 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Instead of trying to loosen up the old bolts, just over-tighten and snap them off. Quick and easy.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-13-2011, 02:28 PM   #9
ubtripn
ubtripn's Avatar
Thanks for the advise all, I really appreciate it!
Old 05-13-2011, 02:35 PM   #10
Classic Heartbeat
The toarch is for cutting the nuts off on the bolts that will ultimately spin on you. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-13-2011, 02:48 PM   #11
Jessechop
do a search on here, I recently typed it out pretty good for a guy on how to do it
Jessechop is offline   Reply With Quote
Old 05-13-2011, 02:50 PM   #12
Jessechop
Here it is
http://67-72chevytrucks.com/vboard/s...d.php?t=460321
Old 05-13-2011, 04:35 PM   #13
ubtripn
ubtripn's Avatar
awesome, thanks!
Old 05-13-2011, 04:42 PM   #14
no moa
no moa's Avatar
Y not buy the whole bed?
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 05-13-2011, 05:17 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by Jessechop View Post
nice work-submitted for a possible FAQ on that!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-13-2011, 06:27 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
A cordless drill may be an easier find and should drill out the spot welds.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-14-2011, 08:15 AM   #17
ubtripn
ubtripn's Avatar
A drill I have. It is in a junkyard or I would go for the whole bed. Well, maybe I still will, they have cheap pices. Found an original general motors horncap in the cab, great chrome condiion (if chrome is what they used.) tghe guy asked me if it was a gascap, got it for 3 bucks.
Old 05-14-2011, 08:29 AM   #18
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I agree 100% also if you have a cordless sawsall to cut the welds it works well
take the wheel tub too the bolts that hold it to the bed are threaded into the bed side if you break one you'll be making more work for yourself...
I would go for the hole bed too depending on your relationship with the yard they make let you take it home strip it and bring back your old stuff....a junk bed is better than no bed
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-14-2011, 09:26 AM   #19
ubtripn
ubtripn's Avatar
good idea or I could bring the whole bed/differential home, swap out my panels and have a matching trailer!
