Old 03-28-2003, 03:16 PM   #1
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
Question mechanical oil gauge? help plz
k im changing out my gauges to a used unit with 100mph speedo and a tach. problem is...my oil pressure gauge is electrical...but the new one is mechanical i think.
the new cluster doesnt have terminals for this gauge, and the printed circut does not go to it either, so that means it would have to be mechanical though right? but the gauge still has three prongs like my electrical one does. what does this mean?
im almost positive i cant just use my old gauge cluster ansd just swap the gauges in(cuz that would be much easier)i would like to use mine if i can. it is in better shape...if this can be done i would like to hear how
but if not, how do i hook up the mechanical stuff?
~1980 c10 chevy scottsdale~
~2.5/4 drop 305/th350c~
c10scotty is offline   Reply With Quote
Old 03-28-2003, 03:36 PM   #2
PHOENIX
mech. will have a spot to screw on a tube/hose. If its a mech gauge, you cant miss it. Only wiring needed on mech. gauge is for lighting.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 03-28-2003, 04:38 PM   #3
crossy
Oh,you can't buy that new
crossy's Avatar
sounds to me like
it actually sounds to me like someone put a mechanical in where an electrical one was and the printed circuit is still there. you can't install a Mech oil press. gauge dash in where an elect one was and have all the gauges work. the elect connector with 18 feeds is wired differently for those 2 dash clusters. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 03-28-2003, 05:41 PM   #4
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
well both gauges look exactly the same...only difference is the printed circuts. so i think the new cluster originally had a mechanical one but for some reason they sent an electrical one with it rather than the mech one...bastards. this sucks
i really cant afford a new oil press gauge right now...is there any way i can get either cluster to work with the electrical oil press gauge and the tach and new speedo plus the gas gauge down in the corner???
Old 03-28-2003, 05:55 PM   #5
crossy
crossy's Avatar
scotty I redo those year dashes all the time especially tach dashes but I don't have a clue what your trying to say or ask now. . If you could send a pic to me at home I would know just by looking. dave
all4trux@snip.net
98 Vortec project.
94,3500,6.5L 4L80
Old 03-28-2003, 06:35 PM   #6
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
crossy thanks for your interest. i do not have a digital camera or a scanner but i will try to explain it better.
i bought a new cluster with tach and 100mph speedo complete with printed circut and everything. i am trying to get it into my truck.
the only problem is that the oil pressure gauge in the new unit is electrical, as is my old setup. but the gauge pod is not for an electrical oil guage (dont ask me why an electical gauge is there). it has an oval mounting hole instead of prongs for the back of the gauge and the printed circut bypasses this gauge alltogether.
so i am pretty sure i will need to rig up a mechanical oil gauge since that is what the pod and circut are set up for. is this right??
i hope that makes sense and thank you very much. also, are there any other problems that you can forsee? will the stock wiring harness work correctly?
Old 03-28-2003, 09:14 PM   #7
crossy
crossy's Avatar
yes, on me understanding now and yes on the MEchanical OP gauge, and i have a few here. BUT!!!!! I would be willing to bet what i said before and i think only 2 of your gauges are going to work. The Mech OP circuits run a different course than the elect ones. you bought a 77-78 cluster . DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 03-28-2003, 09:29 PM   #8
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
k so.....
im screwed? should i just put everything back together and put it up for bids on ebay??
thanks for the help
Old 03-28-2003, 09:43 PM   #9
crossy
crossy's Avatar
you could prove me wrong but I doubt it . it's easy enough to try. just remove your cluster and plug that unit in. please tell me it has a volt gauge and not an amp gauge though or thats a BIG problem. actually you could get a mech OP gauge and put back in it and then sell it correctly . did you pay the usual $100- 150 that ebay gets? if you trace both sets of 'paths' and write it down( the connector is numbered 1-18) you can move the wires in your connector plug. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 03-28-2003, 09:56 PM   #10
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
k ill try that tomorrow and see what happens. yes i did pay that much, and i guess its not a total loss as i can turn around and sell it again. oh well, such is life. it does have a voltmeter btw...i wouldnt have bought an ampmeter
Old 03-28-2003, 10:51 PM   #11
twistedmetal
Take it to the limit
twistedmetal's Avatar
Crossy ,i need to pm you about similar guage stuff,trying to plan ahead.
If Fall Guy only knew how many trucks i've wrecked,He'd be proud
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers
66 Cutlass 2dr hardtop currently undergoing frame off
55 chev 2dr hardtop awaiting attention
85 Chev silverado 1/2 ton loaded,daily driver(stolen)
80 chev silverado 1/2 ton farm truck
87 S-jimmy V-8,lowered ,Parting out
49 Chev 1/2 parting out
parting numerous 73-80 chev trucks
01 Polaris edge X (highly modified)
58 NSU Prima scooter awaiting total restoration
twistedmetal is offline   Reply With Quote
Old 03-28-2003, 11:14 PM   #12
crossy
crossy's Avatar
test the tach first to make sure it is worth the effort. the tach can be tested seperate & easy before installation. If that don't work you'll want to scrap the whole thing when you find out what it costs to get it fixed. thats why my best advice is . " KNOW IT WORKS" . dave
98 Vortec project.
94,3500,6.5L 4L80
