Old 03-28-2003, 04:53 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Overflow can for radiator???
Ok...my friends and I want to go to the first street night at New England Drag way and I was gonna run my truck. I was looking at there rules to see if my truck would pass tech inspection and it will except for one thing...I dont have a overflow an for my radiator. I have a stock radiator and was wondering if there is a cheap and easy way I can get one on my truck so that I can still race on the 2nd of April. Thanks
HotROd
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 03-28-2003, 05:06 PM   #2
fatfords
fatfords's Avatar
Go to your local NAPA or Autozone and pick up a universal overflow tank. Usually less than 5 bones. It has a tube attached to the bottom that you hook to the port on the fill neck of the radiator. If you want a quick and dirty install, attach it with some zip ties to one of the existing holes in the fender, around the battery. Cheap, easy, low cost and you should be able to get in done by April 2nd!
Kent
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 03-28-2003, 05:45 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
In a pinch, I have used the windshield washer reservoir. Drill a hole in the lid for the hose and bolt it to the easiest place you can find. Now, will that meet the race rules??????
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 03-28-2003, 05:52 PM   #4
HotRod929
HotRod929's Avatar
Thanks a lot for the help. 1 more question about the catch can...how big schould it as far as how much it should hold? And when I put it in do I need to fill it with some coolent or is it just there for the overflow? THanks
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 03-28-2003, 06:54 PM   #5
bigjimzlll
bigjimzlll's Avatar
this is a summit brand catch can..under 20.00
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-28-2003, 08:18 PM   #6
Nova_Cobra64
Nova_Cobra64's Avatar
At the local drags they let people through using prestone bottles and 2 litre pop bottles. I think if I decide to race I will make a catch can at school useing stainless steel to make a hexagonal can with the TIG.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 03-28-2003, 08:49 PM   #7
HotRod929
HotRod929's Avatar
bigjimzlll - How is that can pictured mounted where it is?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 03-28-2003, 09:01 PM   #8
bigjimzlll
bigjimzlll's Avatar
there are 2 1/4x20 bosses built in the back of the bottle...I drilled 2 holes in the radiator support and mounted it.
Jim
Anderson,CA
Old 03-28-2003, 10:48 PM   #9
racedvl
racedvl's Avatar
I took this out of a Caprice I think. . . .
racedvl is offline   Reply With Quote
Old 03-28-2003, 11:03 PM   #10
Downtown
Downtown's Avatar
Cool
Here is a picture of my set up. I also used a washer bottle. I didn't drill a hole in the top, I just hooked it up to the top like the washer hose. I also removed the strainer from the bottom of the hose inside the bottle. Drove it like that for two years and never had a problem. It does seem like I changed the cap from 7psi to a 13 psi cap. It was nice because it fit in the small space between the battery and inner fender.
72 Shortbed fleetside 402 BB, AC, Posi
72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new
66 Chevy Caprice 2 dr
74 Honda CB750
New Palestine, IN
Downtown is offline   Reply With Quote
Old 03-29-2003, 12:17 AM   #11
da-burb
"Ochre Ogre"
da-burb's Avatar
Now doesn't that factory tank look nice! My rad caps are 16# on the Chevy trucks. The important thing is to get a cap that is used with a coolent recovery tank. They have a second rubber seal that holds a vacuum when the system cools down.
Old 03-29-2003, 08:32 AM   #12
Andy4639
Old member
Andy4639's Avatar
Cool Over flow
I got this one out of a monte carlo, I think t was a early 70's. It works great.
It's a little dirty, but it's been there for about 175,000 miles so far.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-30-2003, 12:45 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Double check the NHRA (or your local track if they are not the same) but I think the puke tank should hold either 1 or two quarts minimum...just can't remember which.
Old 03-30-2003, 12:56 PM   #14
bigjimzlll
bigjimzlll's Avatar
NHRA is 1 quart
Anderson,CA
Old 03-30-2003, 01:12 PM   #15
GreenMystChevy
I just use the washer bottle in my Chevelle and plan on doing the same for my truck. I left it in the stock location and ran a line all tha way behind the radiator, out of site. Works perfect and you know how those big blocks like to get hot. I didn't have to make any modifications other than running a piece of rubber line to it and making sure that it flowed fine.
As far as how much it expands and retracts, not too much. Just check it now and again. I always keep a little bit in it when engine is cold and then check it when the engine it hot. Good way to check your coolant level!
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 03-30-2003, 01:47 PM   #16
racedvl
racedvl's Avatar
I like the washer solvent bottle idea, but, isn't the nipple on the tank and the nipple for the over flow diffrent sizes?
Old 03-30-2003, 01:48 PM   #17
383 Stroker
383 Stroker's Avatar
Here is a picture of my overflow.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 03-31-2003, 11:23 AM   #18
Lippyp
English Chevy Owner
Lippyp's Avatar
1 litre plastic anti-freeze bottle with a hole drilled in the lid tucked in the corner of the passenger side front fender, as fitted by previous owner. Needs replacing with something more aesthetically pleasing!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 03-31-2003, 01:26 PM   #19
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
I've got a washer bottle as well....
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 03-31-2003, 02:01 PM   #20
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
When I was in college I was a cheap b@stard out of necessity and decided to put an overflow resevoir on my radiator. So, I went to a thrift shop and picked up a Squeeze Bottle from a gas station for $.35 and coincidently the plastic straw fit perfectly inside the existing rubber tube coming off the radiator. I drilled a hole in the side of the battery tray (after removing the battery) and wired it on. It actually worked great. Somehow I lost the bottle during my rebuild, but I will probably put another one on here pretty soon.
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 03-31-2003, 02:26 PM   #21
Ackattack
Ackattack's Avatar
I got a puke can from Summit.
Ackattack is offline   Reply With Quote
Old 03-31-2003, 05:05 PM   #22
Southpa
Southpa's Avatar
Ya can't beat those bottles from earlier full-size Chev cars. They are contoured nicely to fit your inner fender.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-01-2003, 01:58 AM   #23
SWINGSAX68
SWINGSAX68's Avatar
I have an extra washer botle if anyone wants it......If you rust up the inside of the fender nd make it a dirty engine enamel black, and get rid of those colorful hoses DOWNTOWN has my bottle set-up to the teeeee.
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
