Head work
I am installing new valve seals and need some help. It is my first time and I removed my first valve and noticed that OEM seals are o ring style. Now my replacement seals are umbrella style. Do I need to replace the o ring or just use the new style?
Re: Head work
Have used both. The o ring style is oe.the umbrella seal work great .
65 c-10 swb,bbw,step,402/t350,sold!! 1979 c10 Silverado,250,auto,gonna have a 3/5 drop,and twice pipes!Sold Bought the wife a 84 gmc short step |
![]() Join Date: Feb 2010
Re: Head work
Umbrella seals require machining to fit.
Re: Head work
yep gotta trim down the guides
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
Re: Head work
Depends on the style of seal.If they have a ring around the base you will need to have the guides machined.The old style rebuilder umbrella seals just pushed on the guide.Done alot of cylinder heads with no issues.
Re: Head work
Push on umbrellas sounds cool. And cheap: no machining cost!
Re: Head work
Post a picture of the seals you have and we can I dentify them for you .. if it is a late model head some are machined from the factory for seals that grip the guide.. Other than that a simple umbrella seal does just that it does not contact the guide simply makes the oil run over the top not down the guide ..
Re: Head work
I check the item number (Sealed Power ST-2001) and they require machine work.I am going to return them and get a set that does not require machining. Now should I purchase o ring style or get the umbrella style that requires no machining. I have searched that some people have used (installed) both types of sealed on the same valve.
Re: Head work
use both , it's just a bit more protection .... o ring goes on after the spring is compressed ... Believe me , in Detroit I have seen people use the wrong seals .. You may want to check the retainer to guide clearance to make sure the seal is not too tall.........
#10 | |
Re: Head work
Now when I install the O Ring do they go on the first groove or second? |
Senior Car Nut
![]() Join Date: Jan 2008
Re: Head work
bottom groove, top groove is for the keeper. go slowly when you release the spring compressor and guide the retainer as it's coming up so as not to pinch the o-ring
what year are these heads? I thought everthing for the last 30 years was machined for the umbrella's
Larry Last edited by fleetsidelarry; 05-15-2011 at 10:49 AM. |
#12 | |
Re: Head work
I am going to install both O Ring and umbrella style. Fel-Pro SS10058 Fel-Pro SS5112 Thanks for the info First time is always a learning curve! |
