Old Skool Club
![]() Join Date: Jun 2001
What did you do to your truck this week?
There's one of these on the '67-72 page. I'm thinking that these trucks are worthy, also.
So, what did you do to your 88-98, this week? For me, it was a matter of pulling the Century bed cover off and replacing the pinch seal that went onto the bottom of the cover where it rests on the top of the bed. Sure make for a quieter ride...no rattle from the bouncing fiberglass top. What did YOU do?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: What did you do to your truck this week?
well i put the motor in back in my truck after replacing the rear main seal because it let go then i put tailpipes on my truck and mounted some cb whips and painted my rear bumber. dont have any pics but thats what i did
IM ONLY 18 AND LOVIN IT IF MUD AINT FLYIN YOU AINT TRYIN! 1badgmc- Just think. Someone worked hard to make it look that bad. 1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=3839451994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=4388731996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build 1998 GMC K-1500 ECSB 305 auto partd truck 1999 GMC K2500 suburban 350 4x4 Dads project 1981 Corvette 350 auto Also Dads project 1989 Corvette 350 auto ^^ 1998 GMC K1500 ecsb 305 auto Brothers project |
Well, last week I washed and waxed the Suburban. Then it rained.
Got dropped
I went to the garage to make sure it was still there.
93 Chevy C1500 Sport 4/6 Drop, Black and Red Int. 00 K1500 ECSB Z71 Stock Daily Driver w/18" Z71 Wheels |
The One And Only !!!
I LOOKED at mine sitting there every evening when I pulled in after work !
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
here, just not logged in
I installed a '94 excab 60/40 bench seat in my '88. The middle bracket is different on a ex cab, had to cut and weld it to a different angle.
Stock brackets. You can see middle sits higher. Stock angle not even close After all said and done Also i cleaned up some rust from a heatercore leak. No pics, but i also tryed adjusting my p/s gearbox. No luck tho, still lots of slack. |
I walked by my '91 in the garage a few times and looked at the dust collecting on it.
Frequent Flyer
I installed a new bedliner yesterday.
The one I had was fading & scratched up pretty bad. I have replaced a lot of little things on the truck lately to get it all detailed out... I will post new pictures soon. |
i finally got the 454 running right in my 88 sb 5spd(nv3500).....it's also got 3:42 gears,so 1st seems really low to me lol......i'm sure the tranny isn't going to last long so figured what the heck lets help her out a bit,rear diff is lincoln locked....hehehe man is it fun to drive!!!
![]() was out cruising around last nite with it met a few others at a local spot Last edited by 60chvstepside; 05-15-2011 at 11:03 AM. |
Umm, Drove it about 20 miles round trip this week. Not doing good on my plan to drive it more than last year. 2,800 miles put on it last year.
But I am waiting on my amber corners to arrive (B.O.) so I can replace my headlights, turn signal lights and the corner lights. Probably order my tires within the next week or so and order the Bull Bar. RdS
1998 Z71
now that mine got done last weekend we pulled it out of the garage and pulled the 67 swb in to start working on it
67 chevy c 10 2x4 350/700r4 short/fleet 90 Chevy 1500 4x4 350/5 spd short/fleet 90 Chevy 454 ss 93 chevy camaro z28 auto t-tops 2013 Chevy Silverado LT CCSB 4x4 |
New starter. Wooo hooo. I hate that job with a passion.
#13 |
4:13
Started to put in my 4/6 drop and got the entire drivers side front done and then realized I bought the wrong sized spindles(craigslist).Tore it all apart and put it back stock till I can afford new rotors and bearings.
#14 |
Bad 2 weeks for me. First changed the knock sensor on the 93 silverado, code 43 cleared. I had to move this week due to the sale of my house. While pulling the trailer moving, I lost all power and couldn't get the truck to get over 55mph on the interstate. Bad! Changed egr valve, the code went away. Truck started running like poo again. Changed fuel filter, fuel pump. Ran great for 10 miles on the intersate. EGR code is back. Changing the egr solenoid valve tomorrow. Hopefully that will be all I have to do to it for awhile.
66 C10 87 Grand National 95 Buick roadmaster wagon 95 Silverado
#15 |
pulled the intake manifold off because it was leaking water. all the plugs are super brittle and I broke off a bolt. f*ck!
![]() parts pile ![]() sludgy
#16 |
Chris
I cleaned mine up inside and out, took pics, put on the chrome strips to cover the impact strip holes, rerouted my plug wires, all but one(too short) waxxed my underhood chrome, cleaned up some unused wiring and plugins and crap. Put brakes on the wife's car and my father in laws car and changed his oil, plus washed the wife's car, and it rained. Also cleaned the inside of my 88 too. Then washed my brother in laws monte carlo that's sitting in my yard lol.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
#17 |
New registered member here. Thanks for all the great stuff here. I have a 89 GMC K2500 4sp, 5.7L SL. I worked on the interior upgrade to a SLE. Sanded on some of the ruff spots and primered. Trying to get it ready for paint.
#18 |
97' Tahoe 2dr/2wd
I drove mine... and took my wife out in it for our 12yr anniversary...
#19 |
New rims!
#20 |
Nothing this week yet but my 3.73 gears arrived, I'm sending out my '91 gauge cluster to be tested, cleaned, repaired and re-calibrated and the heads for the new engine are going to the machine shop this week.
#21 |
i put intake and head gaskets on my 96 tahoe. Now im having a issue with a miss on cylinder 2 and 3 so im thinking its time to replace the old spider in the intake.
#22 |
Cradle Robber
My 98 3/4 ton kept me pretty busy this weekend.Friday I put on a new alternator and new battery.Saturday I put on new ball joints and wheel bearings,and Sunday I put on new rotors,calipers,and pads.
"The problem with the world is that everyone is a few drinks behind." Humphrey Bogart "Hippies.They're everywhere.They wanna save the earth,but all they do is smoke pot and smell bad."Eric Cartman "Think about how stupid the average person is,and realize half of them are stupider than that."George Carlin |
#23 |
Went back to Wichita Falls to get my new door for my house
#24 |
All the way up here for a door, huh? Seems like a long drive for that.
#25 |
Old Skool Club
I'm thinking that if you can't find it in Bossier/Shreveport, you have Longview, Dallas and Little Rock as well as Texarkana, USA that are closer. Must be something missing in the details of that action......
| Bookmarks |
