want more lift out of rear bags
I put my burb back together and was wondering of a way to get more lift out of the rear. Thye front has crazy lift but the rear has only about 6-7 inches of lift. It has a Pb rear drop member and firestone 9000 bags. Any ideas?
the second pic is all the way up in the rear
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
A guy with a truck
Re: want more lift out of rear bags
Are the bags fully collapsed when aired-out? If not, you could run a spacer. Hard to get any more than that out of a 1:1 set-up...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Put a spacer under your rear bag this will allow more lift.
Justin |
Square
do you plan on ever driving that high anyways? it looks like plenty of lift to get up curbs and speed bumps.
Squarebody Syndicate |
Bags are not fully compressed at full dump. My rear bumper hits before bags compress all the way. They will prob compress 1-1/2 to 2 inches more.
Broey I live in Florida and out streets SUCK! Lol.
What size Rim and tire are you running? From the looks of it they are small. So the rear probably has alot of room to go before bottom out in the notch? I say some bigger tires and a spacer on the bag.
Tony from Norcal Posted via Mobile Device |
Does the front lay frame? DM front also?
No the front needs to cone down some 2 more inches. No DM on front. Just bags and drop spindles.
Cool ride,
2 points of my opinion, 1, your rims dont look from the pictures like they are tall enough, 2, i think your bags should be full collapsed at full drop, if they are not, say for instance 1.5" then i think you have lost 1.5" of lift, Hope this helps, Last edited by roofingbloke; 05-15-2011 at 04:07 PM. |
The wheel and tire combo is 27 1/4 tall. I prob should have gone with a taller rear tire. I'm going to do the spacer on the bag and See how that works.
Good choice, with the rear spacers , low cost & should resolve the problem with the bags fully extending,
#13 |
Square
You can pull the bags out, fully collapse them and then put some tape over the ports. set them in place and see how much space you have left. that will be the exact size of spacer you need, the last thing you wanna do is put a spacer thats too big in.
#14 |
you may want to talk to nate first at porterbuilt, i would think he would design his system to full lift. i think you have a sleeve style bag and they are sensitive to stroke. i ran into the same thing with mine in the back and made a 1.5" spacer. i am runnig a convoluted style bag in the rear, not a sleeve.
#15 |
Juan-
The F9000 should be right at 4.5" when fully compressed. From the pics, it looks like you could get another inch or two out of it. Do what the others have recommended, and use a spacer to get the difference. Just make sure that you don't allow the bag to compress for than the 4.5" as it can damage the bag. If you do the spacer, youu can also remove or change the height of the spacer if you decide to run a taller tire at a later time. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#16 |
nice!
#17 |
Nate is right 4.5 collapsed 9-9.5 bat ride height and 12" extended Ridetech offers 1" spacers you can use one or stack them as needed
