Old 05-15-2011, 10:49 AM   #1
landsurvey1
landsurvey1's Avatar
Aftermarket tach location
I want to install a new tach in the location where a 1971 rear view mirror would go. If anyone has any photos or can suggest how to route the wiring, it would be greatly appreciated Or a photo of any other location that looks good and practical. Thanks for your time.
landsurvey1 is offline   Reply With Quote
Old 05-15-2011, 11:30 AM   #2
sjarrett71
sjarrett71's Avatar
Re: Aftermarket tach location
I would find a location that is as close to in your line if sight while you're driving as possible. That way you don't have to take your eyes off the road as long to see what RPM your engine is at. On the steering column or on the dash or in the gauge cluster seems to be quite popular.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 05-15-2011, 01:31 PM   #3
landsurvey1
Yep, I was thinking on the column but I have tilt steering and it really doesn’t fit very well there. I have an h2o, volt and oil pressure gauge screwed in under the a/c and heater control at the bottom of the dash, so really no room there either. And that location would be about the same as looking at the rear view mirror? The only reason I am even messing with it, is because I am installing a new motor and was looking for something with a little more information on the dial as opposed to stock dash gauges.
Old 05-15-2011, 02:12 PM   #4
Daddy Brim
Daddy Brim's Avatar
The PO installed a aftermarket tach in the instrument cluster, you might haft to do some cutting but it will keep the tach in your line of site.
Daddy Brim is offline   Reply With Quote
Old 05-15-2011, 02:56 PM   #5
sjarrett71
sjarrett71's Avatar
I installed a tilt column also and my tach won't fit on it either. I haven't remounted it anywhere yet. When you get yours mounted make sure to post a pic.
-Scott-
Old 05-15-2011, 03:17 PM   #6
kcsa75
kcsa75's Avatar
Here's where I put the tack on the tilt colum. It's a tight squeeze, but it fits, and there's not issue with the shift lever.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 05-15-2011, 07:11 PM   #7
landsurvey1
Thanks for the photos and comments. I will post a photo when I get it figured out.
