Old 05-15-2011, 11:53 AM   #1
noxided
dually axle c20
Ive got an 8 lug C that i have decided to make into a dually "i need a tow hog" what do i need to do with the axle? can i put dually rims on here, buy adapters or buy a dually axle?
In the front I am going to look for a dually front crossmember and swap it out.
Will the 88-98 front end fit, or just 83-87?
This is my rear end.
noxided is offline   Reply With Quote
Old 05-15-2011, 01:24 PM   #2
Chvyman1975
Chvyman1975's Avatar
Re: dually axle c20
I saw an ad on craigslist a few months back for a guy that had a 65 with the axles off of a 84 dully i think. i was going to buy it but they were just tack welded into place. so i would say those years would work.
Chvyman1975 is offline   Reply With Quote
Old 05-15-2011, 07:11 PM   #3
karlbenz
Re: dually axle c20
depends on the rear drums. if it wasn't set up for duals it probably won't work. I don't think the 88-98 front end will work without major modification
karlbenz is offline   Reply With Quote
Old 05-16-2011, 12:56 AM   #4
Captainfab
60-66 Nut
Re: dually axle c20
An '88-'98 front suspension will not work. You need one from a '71-'87 C30 or thru '91 for the R30. I would suggest switching your HO52 differential, assuming that is what you have, for either a 14 bolt or a Dana 70 that is a dual wheel version.
