Ah oops, Dipstick Move !
Oops, so today I was working on putting my motor back together and I moved some boxes and come to find out I forgot to put the metal tube in to the block and I already put in a upper dipstick tube. Will there be a problem later on down the road. Or should I remove the new upper and try to install the inner tube part. I just finished rebuilding my 307 and i'm just putting on the last couple things
Re: Ah oops, Dipstick Move !
Can't figure out what you are talking about. You only have the tube that the dipstick goes in that fits into the block on the left side.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Yep, when the guy washed my block be popped out the inner tube that is in the block below the upper dipstick on the left side. Just wonder if that will mess something up if i dont put it back. I have the outer dipstick installed on the left side as of now. I got ahead of my self and put stuff together.
You will not hurt anything by not putting it back in. Most guys are not even aware there is an lower tube that goes into the pan area. If the upper tube begins to leak at the block you will know why. I'd put it in while you still have access.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
